Intel vPro® Platform
2783 Discussions
Does AMT work after power failure?
i a have a big problem i need a computer that i can fully control remotely, tha means that i can start it or see it when power returns after a power failure.
because WOL doesn't, is AMT diferent? or AMT shut's down also after power failure and the only way to get the computer back on is to manually start it.
Adolfo_S_Intel2
Yes, as long as AMT is properly configured, it will work for your needs.
Richard_F_Intel1
Yes!
Once power is restored to the system the vPro Manageability Engine (ME) will restart and allow you to remotely manage the system (even if the PC itself has not been powered back on). Once power is restored you can access the ME via a management console or the built-in WebUI and power the system back on.
--Richard
