Intel vPro® Platform
3043 ディスカッション
EMA - Clients not provisioning to CCM or ACM
Jori
ビギナー
6,889件の閲覧回数
So I'm currently trying to POC Intel EMA.  I'll do my best to describe my environment as it is configured...
I have 3 different servers.
svr-emaw - EMA Web and Ajax Server.  URL: emasupport.domain.com
svr-emasrm - EMA Swarm and Recovery Server. URL: emasrm.domain.com
svr-emam - EMA Manageability Server
PC's are all joined to an internal domain (lets just call it, AD.domain.com)
I'm attempting to provision my own machine first, however it will not provision AMT (at all).
Attached are logs from the attempt.  The system I'm attempting to provision is connected via ethernet to the network.
0 件の賞賛
21 返答(返信)
vij1
従業員
6,473件の閲覧回数
Hello Jori,
Greetings!
Please note the latest security updates regarding Intel AMT remote connections:
  1. Use HTTPS (TLS Connection) on Port 16993
  • Non-TLS connections are no longer supported.
  • Supported ports: 16993, 16995, and 664.
  • Example connection: https://<endpoint_IP>:16993.
For more details, please refer to the official Intel AMT Implementation and Reference Guide:
https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments%2Fintelamtandsecurityconsiderations1.htm
Let us know if you need further clarification.
Vijay N.
Jori
ビギナー
6,410件の閲覧回数
The results when attempting to provision with a certificate purchased from DigiCert are the same.
What am I missing?
Jimmy_Wai_Intel
従業員
6,341件の閲覧回数
Hi Jori,
The following error is shown in your manageability server log. Your manageability server is not able to find/talk to the swarm server. Your server and network configurations are where you should start looking for issues.
EMAManageabilityServer, Version=1.14.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - [1] - Error:Unable to connect to a Swarm Server, user=SYSTEM : (TESTCLIENT01,D6890D49).
Would you mind sharing how many PCs are you planning to manage with this multi-server setup?
Jimmy Wai
Technical Sales Specialist, Intel
Jori
ビギナー
6,245件の閲覧回数
Hi Jimmy,
I would say around 800.  The idea behind splitting the servers is less around performance, and more about security posture and monitoring traffic.
I will say this. During installation, the server selected for the Web server/Ajax server installed IIS.  None of the other servers installed IIS. Is IIS a required component for a server that is not hosting the web server component?
Regarding network connectivity.  The manageability server is able to resolve the swarm server.  What ports specifically should I be looking at?
This is how network connectivity currently looks..  I suspect if it is a connectivity issue, then I misinterpreted the documentation and traffic flow.
<> - 2 way connectivity
< or > 1 way connectivity
manageability  <-8000-> swarm
manageability  -8089-> swarm
manageability  -8093-> swarm
manageability  -8095-> swarm
swarm -8094-> manageability
EDIT:
So I took a look at the firewall logs (the 3 servers are on their own isolated VLANs).
I can see my test endpoint communicating with the Swarm server (It detects a SSL connection over port 8080).
During that time I do not see any communication attempted between the manageability and swarm server.  If either one of them attempted to reach the other, I should at least see it block the traffic.
Jimmy_Wai_Intel
従業員
6,227件の閲覧回数
Hi Jori,
Port 8089 between all servers should be both ways. You should also login to the Intel EMA web console with global administrator, and check if all the IP addresses of your server components are correct. Those are under the settings page of each Intel EMA server component. To remove complexity, I would also suggest to provision a PC into CCM first without using the provisioning certificate, i.e. setting an endpoint group with Host Based Provisioning. Once that is successfully, you can than proceed with ACM. You will need to unprovision the PC to change from CCM to ACM.
You don't need IIS running on all servers.
Jimmy Wai
Jori
ビギナー
6,191件の閲覧回数
Hi Jimmy,
Still waiting to get the policy modified on my side.
Is there any diagram or material illustrating what components only need 1 way or 2 way communication?
Thank you very much for your help so far.  Hoping to have some positive results tomorrow!
Jori
ビギナー
6,005件の閲覧回数
Hi Jimmy,
So after doing some double checking, all the rules are in place, and the traffic is NOT being blocked..  However, I do see the servers resetting the connecting, mostly from the server end?
I also don't see anything else in the logs implying that they are unable to connect to each other.  I can confirm that the ports are accessible using Powershell.
Jimmy_Wai_Intel
従業員
5,941件の閲覧回数
Hi Jori,
Have you tried reprovisioning the PC and see if it is successful, or if there are still errors in the manageability server log? Are the in-band functions like terminal and KVMs working?
Jimmy Wai
Jori
ビギナー
5,877件の閲覧回数
Hi Jimmy,
So there was no change in the logs.  Provisioning was still failing with "Error:Unable to connect to a Swarm Server"
I ended up looking at this thread.. Re: Unable to connect to a Swarm Server - Failed PKI provisioning - Intel Community
What I saw was that the Swarm Server, Ajax Server and Manageability Server tab did not have a Swarm Server listed!
So, entering in the IP Address, and the Server ID I managed to set it for the Swarm Server and Ajax Server.  However, the Manageability Server tab I am unable to save on. It is telling me that "File path is not an existing path."
So I have a feeling I'm at least closer to a resolution.  The file paths in the configuration for 'Logs' and 'USBR Images Root Directory' both exist, and the service account EMA is running under has full control over the path.
Jimmy_Wai_Intel
従業員
5,787件の閲覧回数
Hi Jori,
Could you try accessing the web console from a browser on the manageability server, and then try saving the new settings for manageability server?
Jimmy Wai
Jori
ビギナー
5,761件の閲覧回数
Hi Jimmy,
First off, thank you for your patience and continuing to work on this with me.
Second, that did not work, which I kind of expected.  The Manageability Server is only running the Manageability Component and is not running a local instance of IIS.
Would you like me to install the Web Component on that server and try again?
Jimmy_Wai_Intel
従業員
5,664件の閲覧回数
Hi Jori,
Instead, I would suggest creating the USBR directory on the server with AJAX server and IIS running, make sure it has the correct access right, and then try accessing the web console on the server and save the manageability server settings. If this is working, you can then remove the USBR directory on the AJAX server.
Jimmy Wai
Jori
ビギナー
5,403件の閲覧回数
Hi Jimmy,
Creating that directory worked.  My test machine provisioned successfully!
Now that I have a machine provisioned, I am trying to test the management options, but am getting WebSocket errors. Attached are some logs and screenshots.
Jimmy_Wai_Intel
従業員
5,243件の閲覧回数
Hi Jori,
It's great to know AMT provisioning is now working on your server. I'm not familiar with the error in the AJAX server, which may be related to the websocket error you saw. Hopefully, the support team here can help you dig further into that one.
Base on the information we have exchanged so far, there seem to be some issues during the installation with your servers. If you haven't been really using the servers yet, it may be a good idea to reinstall the servers just to remove any uncertainty in the future.
Jimmy Wai
vij1
従業員
6,368件の閲覧回数
Hello Jori,
Greetings!
As you mentioned in your previous post that you are unable to provision the endpoint in either CCM or ACM mode, we kindly request you to perform the following checks on the endpoint:
  1. Verify Port Connectivity:
  • Open PowerShell as an administrator and check the status of ports 8000, 8080, and 443.
  • Run the following commands:
  • Test-NetConnection -ComputerName <FQDN> -Port 80xx
  • Test-NetConnection -ComputerName <FQDN> -Port 443
  • Replace <FQDN> with your EMA server's Fully Qualified Domain Name.
  1. Verify EMA Server FQDN:
  • On the EMA Server, navigate to:
  • C:\Program Files (x86)\Intel\Platform Manager\Platform Manager Server
  • Open settings.txt and look for the following section near the top:
  • emahostname=ematest.intel.com
  • Ensure that the FQDN listed matches the one used in the provisioning process.
Let us know the results of these checks, and we can assist further.
Vijay N.
Jori
ビギナー
6,309件の閲覧回数
Hi Vijay,
So in this case, I have 3 different servers, all with different roles.
Looking at the settings, it looks like the "emahostname" is emasupport.domain.com
The certificate was made for emasrm.domain.com
From my understanding, the endpoints just connected to the swarm server.. So I'm a little unclear why "emasupport.domain.com" needs to be the name on the certificate.
As a follow up to that..  In the scenario where I am trying to manage a device over the internet, would both emasupport and emasrm need to be reachable from an endpoint? Or could emasupport.domain.com stay internal, but emasrm.domain.com be externally available?
Suneesh
従業員
6,277件の閲覧回数
Hello Jori,
Good day.
We would like to inform you that the provisioning failure could be due to an incorrect certificate configuration. The certificate is issued for emasrm.domain.com, but the `emahostname` in `settings.txt` is set to emasupport.domain.com, causing a mismatch.
You may have to verify and correct the certificate configuration to ensure the `emahostname` matches the certificate's Common Name (CN). Additionally, you should check network connectivity and ensure the required ports (8080 and 443) are open between the Manageability Server and the Swarm Server and verify DNS resolution for the Swarm Server to ensure the Manageability Server can resolve its hostname.
We may have to consider these two things:
  1. The certificate is issued for emasrm.domain.com, however the `emahostname` in `settings.txt` is set to emasupport.domain.com.
  2. The logs indicate that the Manageability Server is unable to connect to the Swarm Server during the provisioning process, resulting in a failure.
Suneesh_intel
Jimmy_Wai_Intel
従業員
6,255件の閲覧回数
Hi Suneesh,
A properly issued provisioning certificate for emasrm.domain.com indeed works in this scenario as long as DHCP option 15 is set to domain.com. The CN in the certificate does not need to match the full FQDN of Intel EMA server name or the emahostname in settings.txt. Intel AMT only checks for a depth of 2 or 3 into the DNS suffix in the certificate CN. For .com domains, only 2 levels are checked. In this case, it is only 'domain.com'. The technical reference is here.
Jimmy Wai
pujeeth
従業員
5,454件の閲覧回数
Hi Jori,
Greetings!
We wanted to follow up on this case to check if you had an opportunity to go through the previous plan of action shared.
Feel free to reply to this email, and we'll be more than happy to assist you further.
Pujeeth_Intel
pujeeth
従業員
4,414件の閲覧回数
Hi Jori,
Greetings!
Pujeeth_Intel
返信
