Intel vPro® Platform
3047 Discussions
EMA server v1.11.1.0 install not progressing
Raj_IN
Hello Team,
Its been more than an hour the EMA installation is not completed. Have attached a snapshot. No error was observed till yet and install is simply stuck at the screen as attached.
Please let me know if any steps to be followed for install to start.
MIGUEL_C_Intel
Hello, Raj_IN,
Thank you for using our products.
I believe the Intel® Endpoint Management Assistant (Intel® EMA) installation GUI got stuck.  Did you open Platform Manager and review the installation process?  An alternative option is opening a browser on your EMA server and accessing it with your Global admin account.
It is a new installation; rebooting the Server machine or restarting the EMA services is a good practice.
I look forward to your feedback.
Miguel C.
Raj_IN
Hello Miguel,
Apologies for the delayed reply . As suggested by you, I did open the browser and found able to login using the Global admin account.
Also I could also open the Platform Manager and have attached the snapshot for your reference which shows all servers connected and services running fine.
However the same status is still observed in the EMA server Installer  GUI
Dharmaraj Naidu
MIGUEL_C_Intel
Hello, Raj_IN,
No worries at all.
I am glad to know the new Intel® EMA instance is working.  Regarding the issue with the installer software, I have sent a notification to the engineering team, thank you for your feedback.
I encourage you to start provisioning the endpoints, I will gladly provide further assistance if necessary.
Miguel C.
MIGUEL_C_Intel
Hello, Raj_IN,
I hope this post finds you well.
If further assistance is necessary, please let me know.
Miguel C.
MIGUEL_C_Intel
Hello, Raj_IN,
I am giving you a new follow-up on your post.
Do not hesitate to reply if we can help you with anything else.
Miguel C.
Raj_IN
Hello Miguel,
Greetings...
I have observed few errors/issues as of now.
1.  Does the EMA platform Manager  log off due to inactivity after a specific period and can we incrase this timeout value ? I have to to activate/start the EMA Platform Manager using File/Load Solution option saved in a file with extesion ".pmsol". Have I missed any step or any further configuration required or is this is a normal behaviour of the GUI. For now I have to load the saved solution and use the " Connect to server "  each time
2.  I observed certificate related issues /errors as well
     Am using Chrome v.117.0.5938.132 (Official Build) (64-bit) on the server hosting EMA application. I am unable to open the EMA website using the hostname of the server  but  able to open with IP although with some errors  which I have attached here.
Plaease suggest
3.  Provisioned end points are showing with status as  " CIRA Not Connected"
