Intel vPro® Platform
3052 Discussions
Failed to authenticate with the RCS
Connected to the Intel(R) Management Engine Interface driver, version
8.1.10.1275
Entering
Exiting
Intel(R) AMT in PROVISIONING_MODE_ENTERPRISE
Entering
Exiting
Exiting
Entering
Exiting
Calling function Discovery...
Calling function GetLocalSystemAccount over MEI...
8.1.10.1275
Function GetLocalSystemAccount over MEI ended successfully
Host Based Setup is not supported (WS-MAN call Failed with gSoap error code: 24)
Function Discovery ended successfully
Entering
Exiting
GetHostAndMEInfo output data:
IsAMT:True,
isEnterpriseMode:True,
configurationMode:2,
isRemoteConfigEnabled:True,
AMTversion:8.1.72.3002,
isMobile:True,
provisioningTlsMode:2,
uuid:102FCB6E-7502-11E3-A3B1-D9EEE40120FF,
isClientConfigEnabled:False,
hostBasedSupport:False,
configurationState:2,
FQDN:w1.ex.local,
embeddedConfigurationAllowed:False.
isLANLessPlatform:False.
PKIDNSSuffix: Empty.
***** Start RemoteConfiguration ******
Entering
Exiting
Entering
Exiting
RCSaddress=amt.ex.local, RCSWMIUser=, RCSProfileName=kerb-tls
***** END RemoteConfiguration ******
Exit with code 75.
Details: Failed to complete remote configuration of this Intel(R) AMT device.
Failed to authenticate with the RCS.
A call to this function has failed -
Access denied
Hi vlushchyk,
Following up on your Remote Configuration Service issue. Please provide us more details of your current configuration and what the behavior was using the previous ME driver.
Brand name and model of the host and client pcs.
Current operating system on both sides.
How many pcs are affected by this problem?
Miguel C.
Intel Customer Support
I'm testing to implement AMT.
1. RCS running (network service) - windows 2012 on database-mode installed (Virtual Machine ) sql 2014 express
2. TLS Using ()
AD CA DHCP installed on test ifrastructure
2. client windows 10 (1803 build 17134.165)
When I run cmd on behalf of the domain administrator, the configuration is working. There are no errors. But when run on behalf of the user "RUN AS ADMINISTRATOR" access denied
We need to configure the configuration automatically through Group Policy
Thx,
I resolved this issue
I added group users permission
RCSUtils.exe /Permissions Add "My Group" /RCSNamespace Intel_RCS
Hi vlushchyk,
I am glad to know the problem is resolved. Thank you for your response.
Miguel C.
