Intel vPro® Platform
3072 Discussions
Failed to install MEi using sccm on Windows 10 clients
ARuki
I have troble to install MEi driver and software using SCCM to Windows 10 clients.
From CMD all goes fine, but using sccm is problem.
LOG file:
2017:05:17 11:58:39:691: Effective command line: "C:\WINDOWS\ccmcache\1m\SetupME.exe" -s -report c:\amt.txt
2017:05:17 11:58:39:714: >>> Log start
2017:05:17 11:58:39:721: Mutex with given name doesn't exist. Creating new one.
2017:05:17 11:58:39:730: Obtained mutex succesfully.
2017:05:17 11:58:39:736: Single-instance mutex has been obtained
2017:05:17 11:58:39:743: Core version: 2.6.0
2017:05:17 11:58:39:750: Setup version: 2.3.9.0
2017:05:17 11:58:39:758: Command line: "C:\WINDOWS\ccmcache\1m\SetupME.exe" -s -report c:\amt.txt
2017:05:17 11:58:39:766: OS data: 10-0-1-0 64-bit
2017:05:17 11:58:39:774: System up time: 434 sec
2017:05:17 11:58:39:779: Reboot pending: No
2017:05:17 11:58:39:786: Current UI language: 0409
2017:05:17 11:58:39:794: Language folder: C:\WINDOWS\TEMP\IIFA0A7.tmp
2017:05:17 11:58:40:672: Loading language 0000
2017:05:17 11:58:40:677: E Language load error [2]
Why itš try to load incorect language?
MichaelA_Intel
Rukicc-LV
Thanks for posting this issue. Please note that you will need to go back to your OEM for the issue with this driver as these packages come straight from your vendor. If this is found to be an issue with us, they will work with us directly to resolve.
