Intel vPro® Platform
3045 ディスカッション
How to save the Audit logs to the AD datastore or txt log files on a file server / share?
従業員
2,087件の閲覧回数
Hi vpro Experts,
Now that I got the AMT Audit logging enabled with the Auditor user in place. I am able to pull up the logs on the console and also able to extract them in csv or txt files. However I need your help in going a step further whereby I can integrate and sync the Audit logs with the Active Directory in my environment. Is there a way to extract all the audit logs to be saved in the Active Directory within the respective data store or AD objects? Please help me with either a PS script that could extract the audit logs into respective data stores in a DB server or setup an environment where the respective audit logs for respective vPro clients automatically update / append their respective txt log files on a file server say
\\vproserver\vpro\vproLogs\client1_log.txt?
\\vproserver\vpro\vproLogs\client2_log.txt?
\\vproserver\vpro\vproLogs\client3_log.txt? and so on
\\vproserver\vpro\vproLogs\clientn_log.txt?
Thanks in advance.
Mohammed
0 件の賞賛
1 返信
従業員
1,201件の閲覧回数
Hi Mohammed,
You can find the information that you are looking for at this link.
/community/vproexpert/blog/2012/05/17/ways-to-save-amt-log-data-using-powershell http://communities.intel.com/community/vproexpert/blog/2012/05/17/ways-to-save-amt-log-data-using-powershell
Greg
返信
