Intel vPro® Platform
3045 Discussions
If AVG VPN is active when the Intel Managment and Security Applicaiton service starts, a file called gms.log in SysWOW64 grows at a massive rate (many GB per day), which only stops if you disable the VPN briefly. Is this a known bug? And is there a fix?
CCroz
CCroz
Hi Alberto,
I ran the program and the installation completed successfully. However, the LMS version reported is the same, and I could not find anything to run that would give more information. There is an app that calls itself Intel Management and Security Status, but i can't get much out of it. Access Monitor gives an error (Failed to retireve Access Monitor report).
I exported some information from it:
Item         Value
Operating System Name   Microsoft Windows 10 Pro
Operating System Version   10.0.17763 Build 17763
System Manufacturer   Gigabyte Technology Co., Ltd.
System Name      DESKTOP-PROPER
System Model      To be filled by O.E.M.
Processor      Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz, 2.70 GHz, 4 Core(s), 4 Logical Processor(s)
BIOS Version      American Megatrends Inc.F2
LAN DeviceID      PCI\VEN_8086&DEV_15B8&SUBSYS_E0001458&REV_31\3&11583659&0&FE
LAN Driver      12.15.22.6
WLAN DeviceID      NA
WLAN Driver      NA
And:
MEBx Version   11.0.0.0005
FW Version   11.0.0.1163
LMS Version   11.0.0.1162
MEI Driver Version   12.0.0.1208
MEI DeviceID   PCI\VEN_8086&DEV_A13A&SUBSYS_1C3A1458&REV_31\3&11583659&0&B0
SOL Driver Version   NA
SOL DeviceID   NA
On start-up, the gms.log begins with:
(3644)[2019-06-18 12:06:31.374963] [LM_DEBUG] GmsService:Starting service
(3644)[2019-06-18 12:06:31.374963] [LM_DEBUG] GetAppVersion: Got version: 11.0.0.1162
(3644)[2019-06-18 12:06:31.374963] [LM_DEBUG] Major version: 6, Minor version: 2
It then ends with entries like the following, which it writes at several hundred per second:
(9864)[2019-06-18 12:07:32.706820] [LM_DEBUG] Port: 56689
(9864)[2019-06-18 12:07:32.706820] [LM_DEBUG] LMS:connection attempt was failed on socket:3028
(9864)[2019-06-18 12:07:32.706820] [LM_DEBUG] PFOR: <-- _connect Status: 4294967295
(9864)[2019-06-18 12:07:32.706820] [LM_DEBUG] PFOR: --> _connect
(9864)[2019-06-18 12:07:32.706820] [LM_DEBUG] Port: 56693
(9864)[2019-06-18 12:07:32.706820] [LM_DEBUG] LMS:connection attempt was failed on socket:2892
(9864)[2019-06-18 12:07:32.706820] [LM_DEBUG] Port: 56697
(9864)[2019-06-18 12:07:32.714840] [LM_DEBUG] LMS:connection attempt was failed on socket:2936
(9864)[2019-06-18 12:07:32.716871] [LM_DEBUG] PFOR: <-- _connect Status: 4294967295
(9864)[2019-06-18 12:07:32.726958] [LM_DEBUG] PFOR: --> _connect
If I disable and then re-enable the VPN, there is a transition:
(9864)[2019-06-18 12:09:09.749142] [LM_DEBUG] LMS:connection attempt was failed on socket:2540
(9864)[2019-06-18 12:09:09.750138] [LM_DEBUG] PFOR: <-- _connect Status: 4294967295
(9864)[2019-06-18 12:09:09.750138] [LM_DEBUG] PFOR: --> _connect
(9864)[2019-06-18 12:09:09.750138] [LM_DEBUG] Port: 62023
(9864)[2019-06-18 12:09:09.750138] [LM_DEBUG] PFOR: <-- _connect Status: 2652
(9864)[2019-06-18 12:09:09.750138] [LM_DEBUG] LMS:PFWS: signalled start <=========== THIS IS NEW ==========
(9864)[2019-06-18 12:09:09.750138] [LM_DEBUG] GmsService: sending message to Configurator
(9864)[2019-06-18 12:09:09.750138] [LM_DEBUG] GmsService: sending message - found destination service
(9864)[2019-06-18 12:09:09.750138] [LM_DEBUG] LMS:Connection requested on port 16992
(9864)[2019-06-18 12:09:09.750138] [LM_DEBUG] LMS:received new connection from 127.0.0.1:50316
(3644)[2019-06-18 12:09:09.750138] [LM_DEBUG] GMSC: --> handle_output
And then it settles down and the log stops growing.
Chris
Alberto_M_Intel
Hello Chris,
Thank you very much for the information provided, we are going to analyze the output and will get back to you as soon as possible.
Alberto_M_Intel
Hello Chris,
We apologize for the time this has taken towards a resolution. On one of the previous communications you mentioned you were running LMS version 11.0.0.1162, just to confirm is this the lates version available at the OEM website? And if that is not the case, can you please update to the latest and let us know?
Thank you
CCroz
Hello Alberto,
I am on holiday in Scotland for the next week. I’ll check when I get back.
regards
chris
Alberto_M_Intel
Hello Chris,
Thank you very much for the update, enjoy your travel. We'll be waiting.
Thank you.
CCroz
Hi Alberto,
I downloaded an update from Gigabayte, and the version is now reported as 1911.12.0.1243.
The gms.log problem is not longer occurring!
Thanks for the assistance.
Chris
Alberto_M_Intel
Hello Chris,
I apologize for the late reply, thank you very much for your update.
It's good to hear that the problem does not seem to be happening again.
Don't hesitate to reach me back and let me know if there is anything else we might be able to help you with.
