Intel vPro® Platform
3072 Discussions
Intel SCS Console couldn't discover AMT client machine.
bmj123
Hello - I have just started to explore Intel AMT and I have configured a client for testing, and I could successfully connect to the client's web interface at port 16992 and from the Intel Manageability Commander. However, when I tried to use Intel SCS Console, I wasn't able to discover this client either from entering the Intel AMT FQDN or from Intel AMT IPV4. Pls advise what could possibly be the problem? Thanks.
Emeth_O_Intel
Hi John, Thank you so much for contacting us about this. I was checking the information provided and I would like to share with you the following pdf file about the Intel® Setup and Configuration Software of the Intel® SCS. Please check the link below and take a look into the section 11.4 Remote Connection to Intel AMT Fails. https://www.intel.com/content/dam/support/us/en/documents/software/Intel_SCS_User_Guide.pdf Please make sure that your system have been setup properly according to the guide; if the issue still remain let me know in order to proceed with the next step. Also, please share with us the RCS log in order to verify the system installation as well. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation
bmj123
Hello I used the discovery utility on the client machine with AMT already configured, and the output xml file looks perfectly normal. Also, I have tried to use the Intel Manageability Commander, MeshCommander, MeshCentral… all have good results, just that the Intel SCS Console cannot discover that client machine. Where can I find the RCS log file? Please advise, thanks. Bmj123
Emeth_O_Intel
Hi John, Please check the guide below on the section 3.9.1 - Location of RCS Log Files. https://www.intel.com/content/dam/support/us/en/documents/software/Intel_SCS_User_Guide.pdf Once you will have the information,please share with me the log file in order to proceed with the next step. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation
bmj123
Hello - Pls find the logs in attached, thanks.
bmj123
Hello – I just tried re-installing the SCS. Here are the new log files. Thanks.
bmj123
I’m running the Intel SCS Console on Win 10. Is it not supported? Thx very much.
Emeth_O_Intel
Hi John,
Could you please so kind and provide us the RCS Log again because I cannot see it on the thread, I will appreciate it.
On the other hand, the Intel® Setup and Configuration Software Version: 12.1 is comparable with Windows 10*.
Emeth O.
Emeth_O_Intel
Hi John,
I am following up your case in order to verify if there is something else that I can help you with or if you have any other question.
Please do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
bmj123
Hello there
Sorry have been busy with something else. I missed a step of manually adding the machines to SCS and now I added the machine to SCS. However, when I tried to do further config using the SCS to the client, it did not go through. Don't know what went wrong. Pls see the log files.
J
Emeth_O_Intel
Hi John, Thank you so much for the information provided. Let us check the RCS Log; however, could you please so kind and let me know what is the futher config using the SCS to the client are you refering to? I will be waiting your outcome in order to proceed with the next step. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation
Emeth_O_Intel
HI John, I would like to know if you still have some issues with this deployment? If so, please do not hesitate and let me know and I will be more than happy to assist you. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation
bmj123
Hello I still have problem on applying the pre-configured profile to the AMT device via the SCS Console. I have attached the related log file last time and you mentioned that you would like to take a look at the log file first. Your assistance is much appreciated. Thanks BMJ123 HI John, I would like to know if you still have some issues with this deployment? If so, please do not hesitate and let me know and I will be more than happy to assist you. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation [https://forums.intel.com/img/userprofile/default_profile_45_v2.png?fromEmail=1]<https://forums.intel.com/0050P000007b6Vw?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1561949333853> Emeth_Intel<https://forums.intel.com/0050P000007b6Vw?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1561949333853> (Intel) HI John, I would like to know if you still have some issues with this deployment? If so, please do not hesitate and let me know and I will be more than happy to assist you. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation [Rounded Rectangle: View/Answer] or reply to this email Replying to [https://forums.intel.com/img/userprofile/default_profile_45_v2.png?fromEmail=1]<https://forums.intel.com/0050P0000083JKn?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1561949333853> bmj123<https://forums.intel.com/0050P0000083JKn?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1561949333853> (Customer) asked a question. Edited Tuesday, June 11, 2019 4:03 PM<https://forums.intel.com/0D50P00004MSHAq?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1561949333853&OpenCommentForEdit=1> Intel SCS Console couldn't discover AMT client machine. Hello - I have just started to explore Intel AMT and I have configured a client for testing, and I could successfully connect to the client's web interface at port 16992 and from the Intel Manageability Commander. However, when I tried to use Intel SCS Console, I wasn't able to discover this client either from entering the Intel AMT FQDN or from Intel AMT IPV4. Pls advise what could possibly be the problem? Thanks. [Image placeholder for Capture] Capture [https://forums.intel.com/img/userprofile/default_profile_45_v2.png?fromEmail=1]<https://forums.intel.com/0050P000007b6Vw?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1561949333853> Emeth_Intel<https://forums.intel.com/0050P000007b6Vw?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1561949333853> (Intel) HI John, I would like to know if you still have some issues with this deployment? If so, please do not hesitate and let me know and I will be more than happy to assist you. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation Sunday, June 30, 2019 7:48 PM<https://forums.intel.com/0D70P0000064nhn?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1561949333853> You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in<https://forums.intel.com/_ui/core/feeds/notification/ChatterEmailSettings?setupid=CollaborationEmailSettings&fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1561949333853> as 300002233239@intel.com.isvc<mailto:300002233239@intel.com.isvc>. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums] This message and its contents are confidential. If you received this message in error, do not distribute, use or rely upon it. Instead, please inform the sender and then delete it. Thank you.
Emeth_O_Intel
Hi John, Thank you for the information. We are still taking care of this, please provide us more time in order to verfiy the information. As soon as possible we will get back to you. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation
Emeth_O_Intel
Hi John, We would like to set a session with you, in order to gather more details on this. Could you please so kind and let me know the best time to reach you? I will send you a private email in order to continue with this conversation, please let me know. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation
Emeth_O_Intel
Hi John,
I sent you an email in order to proceed with this conversation over a phone call;
By any chance did you recieve my email?
Emeth O.
bmj123
Hi Emeth Thanks and I received this email. However I don’t want to disclose my contact information in this forum as this would lead to my contact information to be exposed to the public. Is there any way we can contact one another? Thanks Bmj123 Hi John, I sent you an email in order to proceed with this conversation over a phone call; By any chance did you recieve my email? Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation [https://forums.intel.com/img/userprofile/default_profile_45_v2.png?fromEmail=1]<https://forums.intel.com/0050P000007b6Vw?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1562731284670> Emeth_Intel<https://forums.intel.com/0050P000007b6Vw?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1562731284670> (Intel) Hi John, I sent you an email in order to proceed with this conversation over a phone call; By any chance did you recieve my email? Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation [Rounded Rectangle: View/Answer] or reply to this email Replying to [https://forums.intel.com/img/userprofile/default_profile_45_v2.png?fromEmail=1]<https://forums.intel.com/0050P0000083JKn?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1562731284670> bmj123<https://forums.intel.com/0050P0000083JKn?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1562731284670> (Customer) asked a question. Edited Tuesday, June 11, 2019 4:03 PM<https://forums.intel.com/0D50P00004MSHAq?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1562731284670&OpenCommentForEdit=1> Intel SCS Console couldn't discover AMT client machine. Hello - I have just started to explore Intel AMT and I have configured a client for testing, and I could successfully connect to the client's web interface at port 16992 and from the Intel Manageability Commander. However, when I tried to use Intel SCS Console, I wasn't able to discover this client either from entering the Intel AMT FQDN or from Intel AMT IPV4. Pls advise what could possibly be the problem? Thanks. [Image placeholder for Capture] Capture [https://forums.intel.com/img/userprofile/default_profile_45_v2.png?fromEmail=1]<https://forums.intel.com/0050P000007b6Vw?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1562731284670> Emeth_Intel<https://forums.intel.com/0050P000007b6Vw?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1562731284670> (Intel) Hi John, I sent you an email in order to proceed with this conversation over a phone call; By any chance did you recieve my email? Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation Tuesday, July 9, 2019 9:01 PM<https://forums.intel.com/0D70P0000065HjZ?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1562731284670> You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in<https://forums.intel.com/_ui/core/feeds/notification/ChatterEmailSettings?setupid=CollaborationEmailSettings&fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P0000083JKn&s1ext=0&emkind=chatterCommentNotification&emtm=1562731284670> as 300002233239@intel.com.isvc<mailto:300002233239@intel.com.isvc>. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums] This message and its contents are confidential. If you received this message in error, do not distribute, use or rely upon it. Instead, please inform the sender and then delete it. Thank you.
Emeth_O_Intel
Hi Jonh,
Sure, let me share with you the following Contact Support Options:
Please check the following link: https://www.intel.com/content/www/us/en/support/contact-support.html
Go to the section Servers.
My best recommendation will be to provide us a phone call and an agent will get you call and proceed with the next step.
Emeth O.
