Intel vPro® Platform
3079 Discussions
Intel AMT, vPRO HTTPS support
mkoch
A quick question. From which version of Intel AMT or vPro is it possible to access the remote management with HTTPS (encrypted)?
Arun_Intel1
Hi Mkoch,
Greetings!
Please be informed that 16992-16993 port changes were implemented with Core 13th gen processors and 12gen after a BIOS update.
Hence the port 16993 is the one that is open.
Please find the same in the below given note and the link provided.
Starting from Alder Lake platforms with Raptor Lake CPUs running Intel CSME 16.1 firmware,
remote connections to Intel AMT unsecure TCP/IP ports 16992, 16994 and 623 are no longer supported.
TLS ports 16993, 16995 and 664 must be used for connecting to Intel AMT.
Starting from Intel CSME 19 firmware on Arrow Lake platforms, connecting to Intel AMT without TLS is not supported at all (i.e., also local connections must use TLS ports).
https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments%2Fintelamtandsecurityconsiderations1.htm
Best Regards
Arun_Intel
Arun_Intel1
Hi Mkoch,
Greetings!
Best Regards
Arun_Intel
mkoch
So with  CPU Gen 12 and AMT 16 it is possible to use TLS?
And with beginning of Gen 13 it is the default.
Arun_Intel1
Hi MKoch,
Greetings!
To answer your query, by default, Intel® Core 13th gen processors support secure TLS connections only.
Gen 12, after a BIOS update, only TLS is supported.
Older processor versions support non-TLS and TLS connections (at least higher than 7th gen).
Best Regards
Arun_Intel
mkoch
Hi Arun_Intel,
thank you, that answers my question completely.
Arun_Intel1
Hi NKock,
Greetings!
Glad that we were answer your query, and please feel free to contact us going forward for any further query, we are more than happy to assist you!
We shall proceed to close this case.
Best Regards
Arun_Intel
