Intel vPro® Platform
3072 Discussions
Intel DH55TC And Core i7 with Windows XP
hi sir,
i have make new system for my Clint
Intel DH55TC, Core i7 2.28, 4 GB DDR3 Ram and ATI HD 4500 Graphics, 1TB Westren Digital Hard Disk
I install windows XP professional on it but its Performance is very Slow like a Pentium3 :O
Then i install windows 7 Its Performnace is Good but i m not Satisfied still with Core i7
Actually Costomer Demand is windows XP on it.
i tried to install AHCI mode but everytime it giving me Dump error, Update Bios to New Version. Update new Rapid Storage, Update AHCI Driver through Intel Website but Always Dump when i try to install in AHCI mode.
Where is the problem?
My experience with AHCI drivers is that they have to bin integrated into the OS during install. Since this requires a floppy in XP, which most of us don;t have, you can inject the drivers into the OS using tools like nlite (http://nliteos.com/ http://nliteos.com/), and build yourself a custom XP install disk. I've tried multiple times to install the AHCI afterwards and its never worked for me.
I have used nlite (http://nliteos.com/ http://nliteos.com/) to inject the AHCI drivers into the XP OS and create a new install disc. This is the only way I've gotten the AHCI drivers to install properly.
Okz i found something that i change the hard disk Westren Digital to Seagate but in Seagate is 160 Gb and i install Windows XP its working Fine With Good Speed
After that I Change One more new Westren Digital 1TB Hard Disk and install Windows Xp and it give me Same like Before Slow Speed..
Note: i have 2 Westren Digital 1TB hard Disk and i checked in Both.
The 1TB drives need to have the WD Align utility from Western Digital run on them, otherwise your perfomance will be horrible.
Hey there, i see the problem you facing. It must be quite frustrating.
As per my opinion, i think the two recommendations below might help
1-Check your WD hard disk for jumper settings. (not master slave jumper) The jumpers might "LIMIT" the hard disk read speed under some settings. Make sure that if thats the case, you put the jumper settings to the max bandwidth. Eg. there can be settings to limit the hdd's read/write speed to 1.5gbps or 3gbps (although the controllers on Motherboard wont let your hdd run at the speed of 1.5gbps or 3gbps). Since its a new hdd, it might have such setting options. Check them thoroughly
2-Also it turns out that your mother board and processor are not totally compatible with each other, and this might lead to such problems. More info on compatibility with DH55TC can be found at http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=DH55TC http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=DH55TC
Hope this will help.
