Intel vPro® Platform
3065 Discussions
Intel EMA - Provision a machine so you can access it via its IP address
Jools86
New Contributor III
I raised a previous ticket asking how we could provision an AMT chip to be accessed via IP address using Intel EMA.
We received the following from this forum that it was not possible: Connect to an EMA provisioned machine by IP address - Intel Community. It is in fact possible:
Use "Use Intel AMT CIRA unless on a specified network" and add your domain below:
Machines then become connectable via IP and via Mesh Commander:
Can you find out from your engineering team whether this is expected and supported behaviour.
If so, can you let us know how to get TLS working correctly for a machine provisioned via AMT Profile this way, as we see the following when trying to connect to a machine using IMC:
Mesh Commander and Web connection via TLS (16993) work but connection is untrusted, what certs do we have to install and where for a TLS connection of this type to succeed properly.
MichaelA_Intel
Jools86,
You are correct, it is possible if you use TLS relay in EMA whether it's in admin or client control mode.
To get it to work with mesh commander, you have to import the ema mesh certificate onto the local system and in the trusted root for mesh to trust, or under the security menu in meshcommander, you can select ignore certificate.
Unfortunately, there is no way to select ignore certificate in manageability commander.
Victor_G_Intel
Hello Jools86,
Please let me review this information internally, and kindly wait for an update.
Once we have more information to share, we will post it on this thread.
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello Jools86,
To investigate this further on our end can you please clarify if you moved the systems out of EMA to do this current testing? We’re asking because as per your old thread, you were using an EMA provisioned endpoint in ACM.
Additionally, can you describe in more detail the step by step that you did to get the results you got on this new thread?
Victor G.
Victor_G_Intel
Hello Jools86,
Were you able to check the previous message we sent?
Please let us know if you need further assistance.
Victor G.
Jools86
New Contributor III
Hi Victor,
Apologies, I missed this.
The machines were still in EMA. What we did was the following:
1. Create a new AMT Profile as follows:
2. Create a new Endpoint group, with this AMT profile assigned.
3. Deploy EMA Agent to a machine, AMT AutoSetup via EMA Agent then uses the above profile
3. Machines now can be connected directly via 16992 or 16993.
Note: As Intel EMA Console seems to force CIRA when trying to connect via HW Manageability a machine configured as above cannot be connected to via EMA console, we have to connect via MeshCommander or Intel Manageability Commander to the machines via those ports.
Victor_G_Intel
Hello Jools86,
Thank you for your response.
Please allow us some more time to look into this.
Victor G.
Victor_G_Intel
Hello Jools86,
Please bear in mind that once the endpoints have been connected to Intel EMA in ACM the connections are secured and this would prevent other tools from connecting to the endpoint as expected.
Additionally, using mesh commander (3rd patty tool) would not be able to trust the connection because the systems are configured/provisioned in ema, if you remove the EMA provision and then provision the device with mesh commander in ACM you should have a secure connection with mesh but other tools would fail to secure the connection.
Victor G.
Jools86
New Contributor III
Thanks Victor.
The above doesn't hold up in our testing as an EMA machine provisioned using the AMT Profile below can be connected via MeshCommander after it has been provisioned by EMA. This might be a bug / lop
Understood pertaining to TLS not working with an EMA provisioned machine.
Victor_G_Intel
Hello Jools86,
We will check this further on our end and we will reach out as soon as possible.
Victor G.
MichaelA_Intel
Jools86,
Jools86
New Contributor III
Thanks a lot Michael. I had played around with the Mesh cert with no luck, but will try again.
