Intel vPro® Platform
3072 Discussions
Intel EMA - Unable to successfully validate Entra ID (Azure AD) settings
Giri_S
Hello Guys,
We are in the process of setting up Intel EMA in our environment using Azure AD as the authentication method. We have completed the initial configuration steps; however, we are currently unable to integrate Azure AD with Intel EMA. When attempting to connect Azure AD from Intel EMA, we are encountering the following error. Could you please help us identify what went wrong and guide us through the troubleshooting steps or any additional configurations we may need to perform?
1. In your Azure AD tenant (note that this is NOT the same as an Intel® EMA
tenant), create a new app registration. This app will be associated with Intel® EMA
once Intel® EMA is installed, and Intel® EMA will use this app to interact with
Azure AD to exchange information.
a. Go to Azure Active Directory > App Registration and create anew app
registration.
b. Supported account types for the new app must be Accounts in this
organizational directory only.
c. Configure the Redirect URI, choosing Web as the Platform.
d. Enter https://<EMA FQDN or IP>/api/latest/azureLogin as the
Redirect URL value.
NOTE
This URL is case sensitive
2. In the Certificates & Secrets section for the newly registered app, add a new
client secret:
a. At the time of client secret creation, record the client secret's value, as it is
only displayed once. You will need this value later when you configure Intel®
EMA's Web Server settings after installation. Be sure to secure this sensitive
information.
b. Consider the expiration date for the client secret. Note that before it expires,
you will need to create a new client secret and update the Web Server settings
in Intel® EMA.
3. In the API permissions section for the newly registered app, add the required
permissions:
a. Ensure that a "Delegated" permission type for Microsoft Graph with
“User.Read” permission exists.
b. Add a permission for Microsoft Graph with "Application" Type and with
"GroupMember.Read.All" permission.
c. Click to Grant admin consent for these API permissions.
4. Go to Overview section of the newly registered app and copy/record the Azure
AD Directory (tenant) ID, the Azure AD Application (client) ID, to go with the
Azure AD Client Secret Value you created above. Use these values to configure the
Intel® EMA Web Server after initial server installation
Thank you
Arun_Intel1
Hi Giri_S
Greetings!
We see that you are unable to successfully Validate the Entra ID (Azure AD) settings,
Please find the Intel® Endpoint Management Assistant (Intel® EMA) Deployment Guide for Microsoft Azure, in the link given below, and find the Appendix A - Notes on Active Directory Integration for reference.
https://www.intel.com/content/www/us/en/content-details/841816/intel-endpoint-management-assistant-intel-ema-deployment-guide-for-microsoft-azure.html#page=30
Please keep us posted for any further queries or share your observation.
Best Regards
Arun
intel.com/vPro
Giri_S
Hi Arun,
We have installed Intel EMA on on-premises server and trying connect Azure AD from Intel EMA only for user authentication.
When trying to connect Azure AD from Intel EMA by providing the client id, tenant id and client secret as global admin in the initial setup. During this setup, we are getting this error.
Arun_Intel1
Hi Giri_S
Greetings!
We see that you are trying to connect to the Azure AD, from the Intel EMA,
Please refer to the link given below for the prerequisites that needs to be considered for connecting to the Azure AD and share your observations :
https://docs.microsoft.com/en-us/azure/active-directory/hybrid/how-to-connect-install-prerequisites
Thanks & Regards
Arun
intel.com/vPro
Giri_S
Hi Arun,
Thanks for the information.
We have an exisiting Azure AD setup and app registered in Azure AD to connect with Intel EMA.
Arun_Intel1
Hi Giri_S,
Greetings!
Thanks for confirming, please share us your observation if the issue has been resolved after following the document, if the issue still persists, please share the Intel EMA server logs for us to further investigate, and if you would like to share it through the email, please let us know so that we can write an email to your mail id to which you can revert.
Thanks & Regards
Arun
intel.com/vPro
Arun_Intel1
Hi Giri_S,
Greetings!
Thank you for contacting Intel, please feel free to revert for any further query!
Thanks & Regards
Arun
AndreMatsuoka
What was the solution, I have the same problem
Arun_Intel1
Hi AndreMatsuoka,
Greetings!
Please refer to the link below, and refer to the page 45 on Appendix A:
We may have to configure Entra first then install EMA with Entra ID as it is not possible to jump from On-premises to Windows AD or Entra AD.
Please follow the steps given below as well on how to integrate Azure AD with Intel EMA
Integrating Azure Active Directory (Azure AD) with Intel Endpoint Management Assistant (EMA) allows you to leverage Azure AD's identity and access management capabilities for user authentication and authorization within the EMA environment. This integration can streamline user management and enhance security. Here’s a step-by-step guide on how to integrate Azure AD with Intel EMA:
Prerequisites:
Azure AD Subscription: Ensure you have an active Azure AD subscription and administrative access to manage Azure AD settings.
Intel EMA Installation: Ensure Intel EMA is installed and configured in your environment.
Administrative Access: You need administrative access to both Azure AD and Intel EMA to perform the integration.
Steps to Integrate Azure AD with Intel EMA:
1. Configure Azure AD:
Register EMA as an Application:
Log in to the Azure portal.
Navigate to "Azure Active Directory" > "App registrations."
Click "New registration" to register Intel EMA as an application.
Provide a name for the application and set the redirect URI to the EMA server URL.
Configure API Permissions:
After registering the application, go to "API permissions."
Add permissions required for EMA, such as "User.Read" and "Directory.Read.All."
Generate Client Secret:
Go to "Certificates & secrets" and create a new client secret.
Note the client secret value, as it will be needed for EMA configuration.
2. Configure Intel EMA:
Access EMA Console:
Log in to the Intel EMA console with administrative credentials.
Set Up Azure AD Integration:
Navigate to the settings or configuration section related to authentication.
Select Azure AD as the authentication provider.
Enter the application ID, client secret, and tenant ID obtained from Azure AD.
Test Integration:
Test the integration by logging into EMA using Azure AD credentials.
Ensure that users can authenticate and access EMA based on their Azure AD roles and permissions.
3. Manage Users and Roles:
Assign Roles in Azure AD:
Use Azure AD to manage user roles and permissions. Assign users to groups that correspond to EMA roles.
Configure EMA Access:
In the EMA console, map Azure AD groups to EMA roles to control access and permissions.
Additional Considerations:
Security: Ensure that the integration is secure by using HTTPS for all communications and regularly updating credentials and secrets.
Documentation: Refer to Intel EMA and Azure AD documentation for detailed instructions and best practices.
Monitoring: Monitor authentication logs and user activity to ensure the integration is functioning correctly and securely.
By following these steps, you can successfully integrate Azure AD with Intel EMA, enhancing user management and security within your EMA environment.
Thanks & Regards
Arun
intel.com/vPro
Giri_S
Hi Arun,
We have followed the recommended steps; however, when we enter the Azure Entra ID details—specifically the Tenant ID and Client Secret—and click “Save and Sync Web Settings” in Intel EMA, we encounter the error message: “Unable to successfully validate Entra ID (Azure AD) settings.”
Thank you
AndreMatsuoka
These permissions were configured, and the configuration worked
Now I have another error,
added the user, but it didn't go through
log
2025-05-08 15:09:46.4014 [ERROR], Message: Error trying to login with Entra ID (Azure AD), Exception:System.Net.Http.HttpRequestException An error occurred while sending the request. at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at MeshWebCore.WebApi.Frameworks.MicrosoftIdentity.Wrapper.MicrosoftIdentityWrapper.<RedeemAuthorizationCodeForAccessTokenAsync>d__9.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at MeshWebCore.WebApi.Controllers.AzureLoginController.<AzureLoginAsync>d__14.MoveNext()
2025-05-08 15:10:58.6210 [ERROR], Message: Error trying to login with Entra ID (Azure AD), Exception:System.Net.Http.HttpRequestException An error occurred while sending the request. at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
2025-05-08 15:12:45.5481 [ERROR], Message: Error trying to login with Entra ID (Azure AD), Exception:System.Net.Http.HttpRequestException An error occurred while sending the request. at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
2025-05-08 15:18:44.9622 [ERROR], Message: There is no matching State value from the auth code request.
2025-05-08 15:38:48.6294 [ERROR], Message: Error trying to login with Entra ID (Azure AD), Exception:System.Net.Http.HttpRequestException An error occurred while sending the request. at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
Giri_S
Hi Andre,
My server is located behind the corporate firewall. Do I need to open any specific ports to enable communication with Azure AD, or configure any SSL certificates? If so, could you please provide the required port numbers? Also, if SSL is needed, should it be configured with internal one or external one?
Jimmy_Wai_Intel
Hi Andre,
Your EMA server needs to have a valid public web server certificate configured in IIS at port 443. It also needs to be able to access the following URLs without going thru a proxy server.
https://graph.microsoft.com
https://login.microsoftonline.com
Jimmy Wai
Technical Sales Specialist, Intel
Giri_S
Hi Jimmy,
We have got the external certificate but we where unable to bind it to 443 port. Our Intel EMA server is not exposed outside the corporate firewall. Do you have any idea whether the th server needs to be exposed to external network? We are able to bind the internal certificate but not able to bind with external certificate. Could you please suggest and schedule a call if any calls support available for this case?
Thank you
Jimmy_Wai_Intel
Hi Giri,
From my experience with customers, Entra ID integration does require a public certificate installed on the Intel EMA server. Entra ID seems to validate the identity of the server during the registration process. An internal certificate, which cannot be validated, cannot work with the process.
Jimmy Wai
Giri_S
Hi Jimmy,
We have configured the public SSL certificate to the port 443 and the connection is now secure. But still we are getting the same issue. Could you please advise us on this case?
Thank you
Arun_Intel1
Hi AndreMatsuoka/ Guru_S,
Greetings!
Hope the information provided was useful, thank you for contacting Intel!
Thanks & Regards
Arun
intel.com/vPro
Arun_Intel1
Hello Giri_S,
Greetings!
We see that you have configured the public SSL certificate to the port 443 and the connection is now secure. However you are getting the same issue.
To further work upon this issue, we would Suggest you to go through the setup again, parallelly cross checking with the Azure Deployment Guide given below, Just to make sure that we are not missing upon anything, in getting these strings properly configured, such as Client ID, client secret, legit external FQDN (URL) with SSL cert etc.
While doing so, we would request you to carefully configure the details and provide us with logs that has errors, if we are still facing an issue.
Thanks & Regards
Arun
intel.com/vPro
Arun_Intel1
Hello Giri_S
Greetings!
Best Regards
Arun_Intel
kloudmsp
Hello Arun,
I have following this thread and I am also in the same page as Giri, Jimmy.
1.  I have SSL certificate configure on Firewall (SLL offloading) for the Intel EMA URL mean when I access the server from outside it secure.
2.  Followed the below steps "Pre-installation Instructions for Microsoft Azure ADEnvironments"
it seems the steps are not clearly defined on the Intel document
