Intel vPro® Platform
3067 Discussions
Intel EMA 1.14.3 endpoint duplication cleanup setting
JohnBlake
In the Intel EMA 1.14.3 release notes, it mentions “Configurable setting to automate endpoint duplication cleanup”. Where is this setting located? I can not find it on the EMA server and it is not in any of the documentation. Also the documentation only goes up to version 1.14.2.
-thanks
vij1
Hello JohnBlake,
Greetings!
To enable the "Configurable setting to automate endpoint duplication cleanup", please follow the steps below:
  1. Log into the Intel® EMA Web GUI as a Global Administrator.
  2. Navigate to the Settings tab.
  3. Scroll down to the SWAM Server section at the bottom.
  4. Enable the option "Enable HW-based Endpoint Unification via Platform UUID".
This setting will help automate the cleanup of duplicate endpoints based on hardware identifiers.
Please find the screenshot attached for your reference.
Vijay N.
vij1
Hello JohnBlake,
Greetings!
Vijay N.
vij1
Hi JohnBlake,
I am following up on the case and would like to know if I can help you with anything else.
Vijay N.
Suneesh
Hi JohnBlake,
Thank you for contacting Intel.
If further assistance is necessary, please do not hesitate to reply.
Suneesh S
