Intel vPro® Platform
Avisos
3051 Discusiones
Intel Manageability Commander 2.1.133 not installing SCCM Console Extension
ASchmidt
Principiante
2.528 Vistas
I'm installing the Intel Manageability Commander version 2.1.133 on a Windows 2016 Server where we also have the Microsoft SCCM Console version 2010 (from Oct\2020) installed.
The problem is that the SCCM Console Extension from Intel Manageability Commander  does not get installed even though it is supported.
I can see that someone else had this same problem with the previous version and support provided a solution but it was not posted on the forum:
Intel Manageability Commander 2.1.126 not installing SCCM console extension. - Intel Community
Can someone please assist me with this?
0 kudos
4 Respuestas
JoseH_Intel
Moderador
2.518 Vistas
Hello ASchmidt,
Thank you for joining the Intel community
We need to confirm if the SCCM Add-on is compatible with Windows Server 2016 as per it shows compatible to Windows 10, 7 and Server 2012 R2 in the download page. https://downloadcenter.intel.com/download/26506/Intel-SCS-Add-on-for-Microsoft-System-Center-Configuration-Manager
After that could you please attach the URL for the community thread with a similar issue, probably we will be able to find it in our database.
I will look forward for your comments
Jose A.
ASchmidt
Principiante
2.515 Vistas
The link you sent me is for the old Intel® SCS Add-on for Microsoft* System Center Configuration Manager (SCCM) which supports only SCCM 2012.
I'm after the Intel Manageability Commander SCCM Console Extension, which is a different product, and supports the latest versions of SCCM.
Here is the link for the other post with the same issue:
https://community.intel.com/t5/Intel-vPro-Platform/Intel-Manageability-Commander-2-1-126-not-installing-SCCM/m-p/667832#M7367
Cheers,
ASchmidt
JoseH_Intel
Moderador
2.495 Vistas
Hello ASchmidt,
I apologize for the misunderstanding. I found the thread you referred and the solution provided. I will share it with you to your personal email as it is not supposed to be public information.
Let me know is you don't get my email
Jose A.
JorgeA1
Principiante
1.135 Vistas
I'm also havin this issue when installing Intel Manageability Commander version 2.4.0. I don't get the option in the installer panel to select “Microsoft* SCCM Console Extension” to add the right-click context menus into the SCCM Console. Can I also get the solution to this issue?
Responder
