Intel vPro® Platform
3043 Discussions
Intel VPRO
Matthieu2
Hello
I need to deploy the intel vpro version 16 extension with OPTIPLEX AIO 7410 35W as my device.
I am installing intel ema and after trying to access the website interface I had the problem below (see screens).
And the launcher doesn’t work either.
Matthieu2
Now I have this page that appears and each click directs me to an error or to a document that is in my computer.
MIGUEL_C_Intel
Hello, Matthieu2,
Intel® EMA must be installed into Windows Server 2019 or 2022 in English only.  The database must be created with SQL Enterprise 2017 or higher (SQL Express for testing purposes).  Please review and make sure the Server OS, database, and IIS match the EMA requirements.
1.2 Supported Operating Systems
https://www.intel.com/content/dam/support/us/en/documents/software/manageability-products/intel-ema-server-installation-and-maintenance-guide.pdf#page=8
1.3.3 Database
https://www.intel.com/content/dam/support/us/en/documents/software/manageability-products/intel-ema-server-installation-and-maintenance-guide.pdf#page=9
Platform Manager access works with the Global administrator account only.
Miguel C.
Jianyu_Z_Intel
 Your issue is about Intel vPro and EMA products.
 But you create the ticket in Intel AI toolkit forum.
 Could you create your issue in vPro forum: Intel vPro® Platform - Intel Community to get better support?
 Thank you!
MIGUEL_C_Intel
Hello, Matthieu2,
I am following up on the case and wondering if further assistance is necessary.
Matthieu2
Good morning,
I have all the versions to use for intel ema in English but I get stuck and can not move forward.
MIGUEL_C_Intel
Hello, Matthieu2,
I will gladly help you with the issue.
To better understand what is happening, please bring me the configuration details.
Server
OS of the server machine:
SQL version:
Where are the EMA server and database installed?
Intel® EMA software version:
EMA logs from the Server
Default Path: [System drive]\Program File(x86)\Intel\Platform Manager\EmaLogs
Share the ones without the date
EMAlog-Webserver.txt,
EMAlog-Swarmserver.txt, and
EMAlog-Manageabilityserver.txt
Endpoint
OPTIPLEX AIO 7410
Send the Intel® EMA Configuration Tool (ECT) log
https://www.intel.com/content/www/us/en/download/19805/30485/intel-endpoint-management-assistant-configuration-tool-intel-ema-configuration-tool.html
Installation:
Download and unzip the tool.
Double-click the .msi file and follow the prompts.
Run:
a-Open a command prompt as administrator (alternatively, you can run the tool from Windows PowerShell*).
b-Navigate to the installation folder (default C:\Program Files (x86)\Intel\EMAConfigTool).
c-Run the command: EMAConfigTool.exe –verbose
You can reply in the forum or send me a private message.
Miguel C.
MIGUEL_C_Intel
Hello, Matthieu2,
If further assistance is necessary, please share the information requested.
Miguel C.
