Intel vPro® Platform
3045 Diskussionen
Intel don't work after rename server et change ip
AGUNS
Anfänger
3.465Aufrufe
Hello !
The intel ema server was working before making the name and ip change. The server is on windows server datacenter 2019.
When I try to access the server via the web interface, I get errors. I guess the problem is accessing the database (it's on the same server).
In C:\Program Files (x86)\Intel\Platform ManagerPlatform Manager Server\settings.txt I changed the old "emahostname" to the new server name but nothing changes.
In EMAServerInstaller.exe I tried to set the new server name to "database Server" but errors occurred and so the old server name remained.
When I access the database with the "sa" account using Microsoft SQL Server Management Studio, I have full access.
Thank you for your help,
Alexandre
1 Lösung
5 Antworten
AGUNS
Anfänger
3.453Aufrufe
Other: the sa account for the sql database has the sysadmin role and I saw this in the doc:
"If the account used by the Intel EMA services is granted the sysadmin role, and that is later removed, access to the database will no longer work.".
I don't know.
Victor_G_Intel
Mitarbeiter
3.428Aufrufe
Hello AGUNS,
Please share with us the exact steps you used to change the EMA server’s IP and name? Also why did you need to change the EMA server's name and IP?
Victor G.
AGUNS
Anfänger
3.415Aufrufe
This is a vm that has been moved from one hypervisor to another.
The change of name and ip was done in the classic way via windows.
This was necessary and mandatory for the company's network policy.
Thank you for your reactivity,
Alexandre.
Victor_G_Intel
Mitarbeiter
3.299Aufrufe
Hello AGUNS,
Thank you so much for contacting Intel customer support,
We are glad to know that you found a solution. Since the thread is now solved, we will proceed to close it.
Victor G.
Antworten
