Intel vPro® Platform
3052 Discussions
IntelvPro Powershell error "Exception calling "Get" with "0" argument(s): "Unable to connect"
Chris145
New to this, but have some experience with Powershll,
I have some machines set up with Intel AMT, and can accesses them with the web client and can control them with Mesh commander. I'd like to automate their power control with PowerShell, so I have found  IntelvPro.PSM1.
I've manged to get the module installed and appears to be working, however, whichever command I run I get the error "Exception calling "Get" with "0" argument(s): "Unable to connect"
Here is my code:
Import-Module "C:\Bin\IntelvPro\IntelvPro.PSM1"
$AMTCred = get-credential
$powerState = Get-AMTPowerState -ComputerName 'pc.domain.local' -Credential $AMTCred -Port '16993' -TLS
I found I need to explicitly reference the PSM1 file, but this seems to be working.
I get this error:
"pc.domain.local"
"Cannot connect"
"Exception calling "Get" with "0" argument(s): "Unable to connect""
What Have I missed in setting this up or in running this simple commend?
Any help much appreciated!
Victor_G_Intel
Hello Chris145,
To continue with the assistance can you please provide the following:
  1. How many systems are in your current deployment?
  2. Is this a new deployment?
  3. Where exactly did you get the IntelvPro.PSM1 file? If possible, please share the link to it.
  4. Can you please provide us with more information about the machines that you have currently set up? (Model, AMT version, OS build)
  5. Please provide us if possible, with a discovery log of each of the different models of machines that are included in your deployment:
You can find the steps to get the logs below:
  • Download and unzip the Intel® Configurator v12.2
  • https://downloadcenter.intel.com/download/30340/Intel-Configurator
  • Open the unzipped folder, open the Configurator folder and run ACUConfigInstaller.msi
  • Open a Command Prompt window as an Administrator.
  • Go to drive C: \Program Files (x86) \Intel \SCS ACUConfig, and
  • Run the command: Acuconfig.exe /verbose /output console systemdiscovery
  • The discovery log file will be created in the same location the software ACUConfig was installed.
  • Default location: C:\Program Files (x86)\Intel\SCS ACUConfig
Victor G.
Intel Technical Support Technician
Chris145
Hi Victor,
Thanks for getting back me!
    I have 7 machines all the same
    Quite new, I set it up in about May 22.
    The Powershell module comes from intel website: https://www.intel.com/content/www/us/en/download/674527/intel-vpro-technology-module-for-microsoft-windows-powershell-module.html
    All computers are the same.
    Model: HP Z2 G8 Tower Workstation with i7-11700K
    AMT version: v15.0.35
    OS: Windows 10: 21H1 Build 19043.1889)
  5. Please provide us if possible, with a discovery log of each of the different models of machines that are included in your deployment: uploaded PC1.domain.local.xml
  6. Interesting, I got errors when running the Acuconfig tool. see output  in Command log.txt
Does that help?
JoseH_Intel
Hello Chris145,
Looks like you provisioned your systems using the Intel SCS software package. Could you tell what version of the AMT SDK did you installed? The latest version can be downloaded from here: Intel® Active Management Technology SDK
Regarding the error you are facing, please take a look at this article, chances are it could be related: “WsmanUnauthorizedException” Error When Using PowerShell*... (intel.com)
Jose A.
Chris145
Hi Jose,
I don't think I used an SDK to provision them. I just directly accessed the machines (BIOS / UFEI) to turn on AMT - provide passwords etc. After that I was able to add them to Mesh commander, secure them with TLS and access them remotely, both through Mesh Commander or through the web interface.
Is it possible that I have missed some important step which would be done by this SDK?
Regarding your article. that setting appears to be set correctly:
Any other suggestions?
JoseH_Intel
Hello Chris145,
The AMT SDK contains a new PowerShell cmdlet for obtaining Intel UPID information: Get-UniquePlatformIDFeatureInfo.module. I think you might be missing some modules.
Intel® AMT SDK
Jose A.
JoseH_Intel
Hello Chris145,
I am just following up to double-check if you found the provided information useful. If you have further questions please don't hesitate to ask. If you consider the issue to be completed please let us know so we can proceed to mark this thread as closed. I will try to reach you as a very last time on next Thursday 15th. After the thread will be automatically archived.
Jose A.
Chris145
Hi Jose,
Unfortunately, no, I have not been able to resolve this issue, I look a look at the SDK link which was sent, but it did not contain any different instructions to what I had before.
Is there any specific help relating to the error I'm seeing: "Exception calling "Get" with "0" argument(s): "Unable to connect"
JoseH_Intel
Hello Chris145,
We will proceed to mark this thread as closed. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
