Intel vPro® Platform
3072 Discussions
Is there any ISO image file size restriction when using 2 stage boot process?
Hi Experts,
Could you please let me know if we have any ISO file size restrictions when using the 2 stage boot process on the 2nd image that actually needs the system to be reimaged to?
Thanks!
Praveen
Frank_Kuypers_Intel
Hi Praveen,
the 2 stage ISO works by copying the "big" ISO into a ramdisk and then booting from this ramdisk. I do not know the actual size of this ramdisk, but I tried to boot a plain Windows 7 ISO (3.4GB) and it failed as well.
Booting your 4GB image on a 4GB of memory machine will be almost next to impossible using this method.
I guess making the ramdisk size modular through the ISO Builder is probably a good idea.
I hope this helps a bit.
Frank
