Intel vPro® Platform
3049 Discussions
Issues with provisioning AMT in SCCM 2012 R2 - systems previously provisioned in SCCM 2007 R2
CRoss5
ningintelHi - running into issues with reprovisioning some systems for Out of Band in SCCM 2012 R2 that were previously provisioned in SCCM 2007 R2. I ran through the process of unprovisioning the systems in SCCM 2007 before migrating my systems to the new infrastructure as per migration documents from Microsoft.
I was able to provision some systems (currently working with 53 systems while I work out the issues), and have the following numbers:
16 - detected vpro clients
13 - provisioned vpro clients
24 - unsupported vpro clients
The fact that I have 13 provisioned that would lead me to believe that my certificates and environment are set up properly and points me to system specific issue. The 13 provisioned systems where provisioned in our old environment as well.
Here is the log from the AMTOPMGR.LOG file when using the "Discover AMT Status" - I've removed the IP address and full system names from the log.
AMT Discovery Worker: Wakes up to process instruction files SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
AMT Discovery Worker: Wait 3600 seconds... SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
AMT Discovery Worker: Reading Discovery Instruction E:\Program Files\Microsoft Configuration Manager\inboxes\amtopmgr.box\disc\{1DE76692-74CE-48D3-8D80-4CE5828FB3C3}.RDC... SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
SQL>>>set quoted_identifier on;set ansi_warnings on;set ansi_padding on;set ansi_nulls on;set concat_null_yields_null on;set arithabort on;set numeric_roundabort off;set DATEFORMAT mdy; SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
SQL>>>>> Done. SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
AMT Discovery Worker: Execute query exec AMT_GetThisSitesNetBiosNames NULL, '16779993', 'MNC' SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
SQL>>>exec AMT_GetThisSitesNetBiosNames NULL, '16779993', 'MNC' SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
AMT Discovery Worker: CSMSAMTDiscoveryWorker::RetrieveInfoFromResource - Found machine (), ID: 16779993 IP: from Resource 16779993. SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
AMT Discovery Worker: Execute query exec AMT_GetAMTMachineProperties 16779993 SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
SQL>>>exec AMT_GetAMTMachineProperties 16779993 SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
Discovery will use ip resolved from netbios: SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
AMT Discovery Worker: Execute query exec AMT_GetProvAccounts SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
SQL>>>exec AMT_GetProvAccounts SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
AMT Discovery Worker: Finish reading discovery instruction E:\Program Files\Microsoft Configuration Manager\inboxes\amtopmgr.box\disc\{1DE76692-74CE-48D3-8D80-4CE5828FB3C3}.RDC SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
AMT Discovery Worker: Parsed 1 instruction files SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
AMT Discovery Worker: Send task to completion port SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
General Worker Thread Pool: Current size of the thread pool is 1 SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
General Worker Thread Pool: Work thread 10684 started SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 10684 (0x29BC)
Discover using IP address SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 10684 (0x29BC)
DoPingDiscoveryForAMTDevice succeeded. SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 10684 (0x29BC)
AMT Discovery Worker: 1 task(s) are sent to the task pool successfully. SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
SQL>>>SELECT SC.SiteType FROM SMSData S INNER JOIN SC_SiteDefinition SC ON SC.SiteCode = S.ThisSiteCode SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
SQL>>>SELECT dbo.fnIsSnapshotInitializing(N'Site Control Data', N'') SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
SQL>>>select DateLastModified from SiteControl where SiteCode = N'MNC' SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
STATMSG: ID=7203 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_AMT_OPERATION_MANAGER" SYS= SITE=MNC PID=2964 TID=6520 GMTDATE=Thu Feb 13 14:30:10.716 2014 ISTR0="1" ISTR1="0" ISTR2="0" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=0 SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
AMT Discovery Worker: There are 1 tasks in pending list SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
AMT Discovery Worker: Wait 20 seconds... SMS_AMT_OPERATION_MANAGER 13/02/2014 10:30:10 AM 6520 (0x1978)
Error 0x80090304 returned by InitializeSecurityContext during follow up...
IT_C_Intel
As a reminder, direct support from Intel engineers is available at https://bizsupport.intel.com/ https://bizsupport.intel.com.
