Intel vPro® Platform
3077 Discussions
Looking for a current Document on how to configure a Small PC Network AMT/KVM . The one I found was published in 2010 and does not work.
LRobi16
SergioS_Intel
Hello LRobi16,
We are sorry to hear that issue that you are having configuring your AMT system, can you please share with us the link that you are referring to?
We also would like to share the following video in order to enable Intel(R) Vpro system:
https://www.intel.com/content/www/us/en/support/articles/000026592/technologies.html
You can also check the following information:
Intel® Setup and Configuration Software (Intel® SCS)
https://www.intel.com/content/dam/support/us/en/documents/software/Intel_SCS_User_Guide.pdf
Additionally, you can check the Intel® AMT Configuration Utility:
https://www.intel.com/content/dam/support/us/en/documents/software/manageability-products/Intel_AMT_Configuration_Utility.pdf
Sergio S.
SergioS_Intel
Hello LRobi16,
We appreciate the additional information, did you try the links that we sent you on the previous post and try to setup your AMT system?
Additionally, can you please share with us more information about your system configuration? i.e. System model, AMT version, processor, etc.
Also, please let us know when exactly are you getting the error message and please share what does the error message says.
Sergio S.
SergioS_Intel
Hello LRobi16,
We are following your questions and we would like to know if you need further assistance.
Sergio S.
SergioS_Intel
Hello LRobi16,
We are following your questions and we would like to know if you need further assistance or if we can close this thread.
Sergio S.
Emeth_O_Intel
Hello LRobi16,
I hope you find very well.
I am following up on your case in order to verify if you still have questions about the Intel Active Management Technology. If so, please let us know and we will be more than happy to assist you.
Emeth O.
Intel Server Specialist.
LRobi16
I attempted to install the a small PC Network using the instructions sent to me but is failed to create the bootable flash drive. The Active Manager wizard was installed on a server and the flash drive was created by that application. We need this to work as we have an Imaging and Packaging testing lab for several International clients and would like to use this replacing IP/KVMs that require expensive connectors and do not work on all laptops or desktops. We use these units to give remote access to off shore imagers and packagers, I used Flash drives that were under 2 GB. I followed the Video installing Active Management.
SergioS_Intel
Hello LRobi16,
We are sorry to hear about your inconvenience.
Can you please let us know how many systems are you trying to install AMT?
Also, please let us know when exactly are you getting the error message, and please share what does the error message says. If possible please provide us a screenshot of the error message.
You can also check the following URL, in order to setup AMT:
https://www.intel.com/content/dam/support/us/en/documents/software/Intel_SCS_User_Guide.pdf Page 85.
Sergio S.
LRobi16
We have several clients that have up to 40 PCs. They are all on an isolated vLan for each client with a server on the data floor connected to the client vLan. I am working from home for three weeks and cannot start the user’s guide in the Testing Lab until that passes. We are observing Corona Viral protocols so my co-worker is in the lab for these three weeks. I will start the User’s Guide, Page 85 when I go back to the Lab.
SergioS_Intel
Hello LRobi16,
No problem, we are going to keep this thread open as long as you need. I will follow up with you next week or if you prefer a specific date please let me know.
Sergio S.
SergioS_Intel
Hello LRobi16,
I am following your question, and we would like to let you know that we are going to keep this case open.
Sergio S.
LRobi16
Thank you, I will be back in the Lab in two weeks (internal COVID-19 protocols) and able to run the install on a server.
SergioS_Intel
Hello LRobi16,
I hope this message finds you safe, I will follow up with you in 2 weeks.
Sergio S.
SergioS_Intel
Hello LRobi16,
We hope this message finds you safe, we are following your issue and we would like to know if you were able to follow the steps that we provided you on our previous posts.
Sergio S.
LRobi16
I will be in the Lab 6/8/2020 and will install AMT via the users guide again as per page 85.
SergioS_Intel
Hello LRobi16,
No problem I will follow up your thread on 6.15.20
Sergio S.
SergioS_Intel
Hello LRobi16,
I am following your question, and we would like to let you know if you were able to perform the tests and install AMT.
Sergio S.
LRobi16
I just now got to the Lab for this week but I am involved in other things right now. I will try to install it this week.
SergioS_Intel
Hello LRobi16,
No problem I will follow up your thread on 6.26.20.
Sergio S.
Emeth_O_Intel
Hello LRobi16,
I am contacting you on behalf of my co-worker Sergio.
I was reviewing your thread and I would like to know if you have some questions or additional information to share with us.
If so, please let us know and we will be more than happy to proceed with the next step.
Emeth O.
