Intel vPro® Platform
3049 Discussions
Seeing failures while executing PETS test package from command line
Manjuna
Hi Team,
We using PETS (Platform Enable Test Suite) and executing test pre provided test package. here is out observation.
We are able to successfully import SUT and run test package from PETS console on server side.
The same is exercised via command line and seeing failures. attached are the error screen shots.
Need your support in successfully exercising PETS test package from command line.
Wanner_G_Intel
Hello Manjuna,
Thank you for posting your question on this Community.
We will review your inquiry to update this thread soon.
Wanner G.
Wanner_G_Intel
Hello Manjuna,
This is an update to your thread.
Because of the software package you are using, I recommend that you contact your Field Application Engineer or Field Sales Engineer to obtain further assistance.
If your company does not have a FSE or FAE assigned, you can contact an Intel® Authorized Distributor.
Intel® Authorized Distributors and Approved Suppliers
https://www.intel.com/content/www/us/en/support/articles/000015067/programs.html
I hope you find this information helpful. I will proceed to close this thread.
Wanner G.
