Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
intel AMT computer don't Remote Power UP
AMT hardware configuration
CPU:E6550
Motherboard:DQ35MPE, BIOS version:JOQ3510J.86A.0191.2007.0427.1530, 82566DM LAN
i use intel amt dtk tools:Intel AMT Commander
command Success
power down yes
Normal reboot yes
pwoer Up no(after send "Power down" command, ping Target computer is not success)
In addition, AMT status indicator lights have been flickering
Manual instructions AMT in the M1 state
Is this why?
M1 state what is the meaning?
Brian_Cockrell
Try the following to resolve your issue:
1. Update your BIOS. The BIOS version you are using is very old. The latest BIOS is available here: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&Inst=Yes&ProductID=2784&DwnldID=15268&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
2. Navigate to "Intel Management Engine Configuration" in your ME/BIOS. Ensure that "Turn on Intel Me in Sleep States" is set to "Always/Enabled". If it is set to "Never/Disabled" then the ME will turn off when the PC enters a sleep state and you will not be able to power it up.
