Intel vPro® Platform
Annonces
3077 Discussions
unconfigure AMT fails in ACUConfig
MPala11
Nouveau contributeur II
3 775 Visites
I'm able to configure AMT 7.0 using ACUConfig with ConfigViaRCSOnly in admin mode.When I tried unconfigure option it's failing with error as
Error in ConfigurationReset (0x81c) 2076.
What could be the reason for failure?
Command used
ACUConfig.exe /Verbose /output Console Unconfigure /AdminPassword mailto:P@ssw0rd P@ssw0rd /RCSAddress 192.168.10.12 /Full /WMIUser domain\username /WMIUserPassword password
Console log
Starting log 2011-05-19 17:02:08
Verifying the digital signature of ACU.dll, this operation might take up to 3 minutes...
The file "ACU.dll" is signed and the signature was verified.
***** Start CheckAMT ******
Connected to the Intel(R) Management Engine Interface driver, version 7.0.0.1144
Intel(R) AMT in PROVISIONING_MODE_ENTERPRISE
***** Start FWUpdateData ******
***** END FWUpdateData ******
***** END CheckAMT ******
***** Start GetAmtFQDN ******
***** END GetAmtFQDN ******
Calling function Discovery...
Calling function GetLocalSystemAccount over MEI...
Function GetLocalSystemAccount over MEI ended successfully
Host Based Setup is supported
Current Control Mode : 2 (Admin)
Allowed Control Modes : 2 (Admin) and 1 (Client)
Function Discovery ended successfully
xxx.xxxx.com:Starting Unconfigure...
***** Start Unconfigure ******
***** Start TcpIpDiscovery ******
***** END TcpIpDiscovery ******
Start AdminUnconfigure
Connection data - Connection type: HTTP, FQDN: xxxx.xx.xxxxx.com, IP: 127.0.0.1, UserName: admin
Connection Infoxxxx.xx.xxxxx.com admin HTTP_CONN:
WS-Management call GetAmtVersion (CIM_SoftwareIdentity.Get) ok
AMT version-7.0.4, AMT SKU-16392, AMT Level-2
WS-Management call GetSupportedFeatures (CIM_RegisteredProfile.Enumerate) ok
WS-Management call GetSupportedFeatures (AMT_CryptographicCapabilities.Get) ok
WS-Management call GetSupportedFeatures (CIM_EthernetPort.Get) ok
WS-Management call GetMachineName (AMT_GeneralSettings.Get) ok
xxx-xxxx.xx.xxxxx.com.com
WS-Management call GetWiredNetworkSettings (IPS_IPv6PortSettings.Get) ok
WS-Management call GetWiredNetworkSettings (CIM_ElementSettingData.Enumerate) ok
WS-Management call GetWiredNetworkSettings (EthernetPortSettingsObj.Get) ok
-DHCP Enabled
Failed while calling WS-Management call ConfigurationReset (AMT_SetupAndConfigurationService.InvokeUnprovision). Intel(R) AMT connection error 2076: AMT Status code - Blocking component.
WS-Management call ConfigurationReset (AMT_SetupAndConfigurationService.InvokeGetUnprovisionBlockingComponents) ok
error status: 0x81c
Intel(R) AMT unconfiguration failed. Error in ConfigurationReset (0x81c) 2076
Exit AdminUnconfigure
Unconfigure Admin Control Mode failed: Returned code: 0xc00007d5 - Intel(R) AMT Unconfiguration failed.
RCSaddress=192.168.10.12, RCSWMIUser=domain\username, UUID=E06C0792-7535-11E0-AADD-04175D769909, FQDN=xxxxx.xxxx.xx.xxxxx.com, IP=192.168.0.205, Full Unconfigure=Y, ADOU=
Intel(R) AMT Operation failed. (0xc00007d5) ((ExecMethod Unconfigure) Intel(R) AMT unconfiguration failed. Error in ConfigurationReset (0x81c) 2076)
Call to function failed with return code (0xc000003b) (Intel(R) AMT UnConfigure failed. -0xc00007d5. ( Unconfigure Admin Control Mode failed: Returned code: 0xc00007d5 - Intel(R) AMT Unconfiguration failed. Intel(R) AMT unconfiguration failed. Error in ConfigurationReset (0x81c) 2076) )
***** END Unconfigure ******
Exit with code 45 - Failed to unconfigure this Intel(R) AMT device.
Details: Intel(R) AMT UnConfigure failed. -0xc00007d5. ( Unconfigure Admin Control Mode failed: Returned code: 0xc00007d5 - Intel(R) AMT Unconfiguration failed. Intel(R) AMT unconfiguration failed. Error in ConfigurationReset (0x81c) 2076)
Mani
3 Réponses
Employé
2 154 Visites
Hi Mani,
Could you please run the Diagnostic Utility found at this URL on the Expert Center:
/docs/DOC-5582 http://communities.intel.com/docs/DOC-5582
Please attach the result file to this Thread.
David
0 Compliments
Employé
2 154 Visites
Hi Mani,
Were you able to run the diagnostic utility?
David
0 Compliments
ccede
Débutant
2 154 Visites
Hi
I understand this thread is over a year old, but I am having the same issue with one of my machines. The machine is an HP EliteBook 8460P running Windows 7 Professional x64
I am running the same command as Mani is above (with correct username/passwords). The error messages & codes are also the same as mentioned above by Mani.
Also - attached is the AMT Diagnostics Tool result file (renamed to .txt file extension)
I also tried to unconfigure the machine via the BIOS/ME but it failed as well.
Any suggestions would be greatly appreciated! thanks guys!
Here is a screenshot from the SCS 8.1 console (Monitoring Section):
0 Compliments
Répondre
