Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3089 Discussions
vPRO Remote Configuration error
Hi all!
My problem regards remote provisioning of intel vPRO desktops. I do have remote configuration certificate from verisign (it`s imported to personal certificate store of local machine as well as local user ) but when machine sends hellows scs throws such errors:
The SOAP connection with connection parameter set # 1 failed: AMT Connection Error: SOAP Error [26]: "getFullCoreVersion: Fault: 'EOF was observed that violates the protocol. The client probably provided invalid authentication information.' : Details: 'SSL connect failed in tcp_connect()'".
The SOAP connection with connection parameter set # 2 failed: AMT Connection Error: SOAP Error [26]: "getFullCoreVersion: Fault: 'Error observed by underlying BIO: Bad file descriptor' : Details: 'SSL connect failed in tcp_connect()'".
I tried with my own generated remote certificate as well, I did suplly hash through MEBx and the same errors apear.
Any help would be very much appreciated, because I`m struggling with it almost 2 weeks. Thanks in advance.
so first thing to confirm is you have upgraded to the latst BIOS/ME FW from your OEM, Verisign upgraded there certs about 8 months ago and we had to upgrade our certs in the FW - ther shoudl be a vPro article posted her about it. If you still ahve problems I will need to knwo more details on the following
1. What veriosnof SCS?
2.What OEM platform
3. Waht is the BIOS
4. What is the MEFW - its typically a splash screen at boot time
Hi there,
I also have same this error.But I used the PSK mode.
And I used SCS 5.3 AMT 3.2.
The SOAP connection with connection parameter set # 2 failed: AMT Connection Error: SOAP Error [25]: "getFullCoreVersion: SOAP Unknown error".
Giggs
