You can find information on your processor here:
As for memory type and support, contact your motherboard/system manufacturer.
Doc
Since, in that generation, the Memory Controller was in the chipset (GMCH component), it is the motherboard and the version of the chipset that is used on this motherboard that determines the type and amount of memory supported. Bottom line, you need to contact the board manufacturer to find out the answer to both questions.
Здравствуйте, уважаемый Н.Скотт.Пирсон! Благодарю Вас за оперативную отзывчивость и за информативный ответ. Будьте здоровы. Удачи. С уважением, Виктор Александрович.
