I'm installing D415 on ubuntu 16.04
On following the instruction manual https://github.com/IntelRealSense/librealsense/blob/master/doc/distribution_linux.md
, i ended up with an error on running realsense-viewer
"realsense-viewer
31/10 12:04:45,653 ERROR [140307828632128] (backend-v4l2.cpp:518) Cannot access /sys/class/video4linux"
My Kernel version is 4.15.0-36-generic
I googled and tried various solution but still no success. Please help!!
In a previous case last month of this error at the same line (backend-v412.cpp line 518), the user corrected the problem by doing a completely fresh install. They believed the cause may have been that they had their kernel versions mixed up.
https://github.com/IntelRealSense/librealsense/issues/2427# issue-362556361 realsense-viewer: Cannot access /sys/class/video4linux · Issue # 2427 · IntelRealSense/librealsense · GitHub
Installing fresh Ubuntu would take a lot of time since i have ROS packages and many other things installed.
The official Ubuntu documentation has advice about removing old kernels. In practice though it may be too risky on your installation, as pulling out a kernel one or more of your programs depends on could create all sorts of problems.
https://help.ubuntu.com/community/RemoveOldKernels https://help.ubuntu.com/community/RemoveOldKernels
I wonder if an alternative would be to create a separate Ubuntu installation on a USB stick (a 'boot stick') just for Librealsense, so that you don't break your existing installation.
https://tutorials.ubuntu.com/tutorial/tutorial-create-a-usb-stick-on-ubuntu# 0 Create a bootable USB stick on Ubuntu | Ubuntu tutorials
I solved the issue.
DO everything and just install sudo apt-get install realsense-uvcvideo
Great news! I'm really pleased you found a solution. Thanks for letting us know!
It was working fine till yesterday and now it doesn't even detect the camera. I'm getting the same old error "Cannot access /sys/class/video4linux"
Could you please help me resolve this issue.
Hello shrijan00,
Could you please let us know the output of: lsusb ?
Also, could you please update the firmware to the latest release? Link to the instructions http:// https://www.intel.com/content/www/us/en/support/articles/000028171/emerging-technologies/intel-realsense-technology.html here and you can download the firmware from https://downloadcenter.intel.com/download/28237/Latest-Firmware-for-Intel-RealSense-D400-Product-Family here.
Looking forward to your reply!
Eliza
So i uninstalled and did once again, so it is working for now.
But when using the roslaunch i'm still getting this error but using rqt_image_view iḿ still able to see image but i think this error is either due to kernel issue or sdk.
And when i run realsense-viewer, it works but in the terminal it keeps telling "UVC metadata payloads not available. Please refer to installation chapter for details."
Hello shrijan00,
On this https://github.com/intel-ros/realsense/issues/503 thread a solution for this error message is to install librealsense2-dkms with
sudo apt-get install librealsense2-dkms=1.3.1-0ubuntu3
I noticed that you have posted this issue on another thread too - https://intel-openport-v8.hosted.jivesoftware.com/thread/130792.
Would you agree to continue the conversation there to avoid redundancy?
Thank you,
Eliza
Running that command, it doesn't even detect now. I removed it so at least it is working somehow withe warning
[ WARN] [1541544389.804503667]: Frame metadata isn't available! (frame_timestamp_domain = RS2_TIMESTAMP_DOMAIN_SYSTEM_TIME)
![](/skins/images/1FC86CD46823E418D1E2B7B4DC10231C/responsive_peak/images/icon_anonymous_message.png)
