Items with no label
3338 Discussions
Changing video width and height
SMish7
I want to view the video stream from the RGB camera in 640X480. Is it possible to change this parameter? if so, how?
Hello SubMarIn,
Thank you for contacting us.
If you are trying to do this on Euclid, you have to change the color_height and color_width parameters in this launch file: https://github.com/IntelEuclid/realsense_camera/blob/master/launch/lr200m_nodelet_default.launch. The file can be edited directly or using the Euclid browser interface. The easiest way to do this using the Euclid browser interface is described in the attached document.
I hope you find this helpful.
Have a nice day.
Leonardo R.
jb455
Valued Contributor II
The https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?enablestreams_pxcsensemanager.html EnableStream method allows you to specify the resolution for each stream. For a more robust way (ie, checking which resolutions the camera supports first then picking one of them), look through the RawStreams sample to see how the streams are enabled there.
Hello SubMarIn,
Have a nice day.
Leonardo R.
SMish7
Hello SubMarIn,
It was a pleasure to help you.
Feel free to contact us anytime.
Leonardo R.
