Items with no label
3338 Discussions
Eucli temperature issue
VTalo
I have troubleshooting with my Euclid.
The temperature is very hot (up to 75 degC in monitor), and after 10-15 minutes of usage, the Euclid switch off… I use only tutorial scenario. When the Euclid cools it restarts ... (after 5 minutes). But since today Euclid refuse to start…
Have you the same issue? And what you advise me to do ?
Thank you in advance
MartyG
The Euclid's data sheet says that it can handle a maximum of 35 degrees external air temperature.
I was not sure whether you meant that it was 75 degrees weather in your location or 75 degrees temperature inside the Euclid's casing.
If it is inside the casing, it sounds like you are running a program that is pushing the Euclid's processor chip very hard and radiating a lot of heat from it, causing shutdown because the cooling fan in the Euclid cannot cope with it.
What is the weather like in your location? Hot weather and / or thin air (e.g in high mountainous locations) can cause a fan to struggle more than usual. A symptom of a struggling fan is it making more noise than usual as it works harder to try to keep the processor temperature down.
Also, Ubuntu's 'System Monitor' window could show you what processes are running so you can see what is causing high processor load.
VTalo
The external temperature (ambient) is roughly 28-30 degC
The temperature of 75 degC is read in the Euclid interface (10.42.0.1/# system/status) : "System status" in "Utilities Tab"
This morning temperature in France is lower (20 degC), but the Euclid don't start! There is just a big fan noise…
Is it possible to burn the Euclid just by playing the prerecorded scenario with the Turtlebot?
Best regards
Vincent
MartyG
The shutdown mechanism when the internal temperature becomes too hot is designed to stop damage being done to the hardware by giving the device a chance to cool down. So if the shutdown mechanism is working correctly when temperature becomes excessive then there should not be permanent damage. If the temperature rise is sudden though then this is not a guarantee of avoiding burn damage.
Years back, I was working on upgrading a Celeron PC with the casing open and had the processor instantly burst into flames on startup because I hadn't seated the processor's pins in the socket properly! An extreme example, but it killed the processor because there was no way back from sudden heat death like that.
If the Euclid were working correctly then if it thought the temperature was excessively hot, I would expect the BIOS to automatically shut the Euclid down, not stay on with the fan running. That symptom does not sound encouraging, unfortunately. If you need to return your Euclid to Intel for refund or replacement, you can do so by emailing mailto:click.support@intel.com click.support@intel.com
Amit_M_Intel
hi,
If the fan is working, it means that the kernel booted.
Can you connect it to a screen?
How Euclid is mounted on the turtlebot?
thx,
Amit
VTalo
I try the tow solutions, a direct connect with HDMI wire and with VNC… but the tow method doesn't work. The Euclid is screwed on a column which itself is fixed on the turtle.
Amit_M_Intel
Sounds like a problematic system.
I will check with the team. try emailing the click support team as MartyG suggested in parallel.
VTalo
The Euclid is retrun to Click Store, Aurora, Colorado...
I hope recieve a new one that work perfectly
Thank all for your help
