Items with no label
3338 Discussões
Connector info for Eucid Uart and Power Adapter Plate
DNiel2
Novo colaborador I
2.618 Visualizações
I we get the pin outs and connector type so we can build up our own cables?
10 Respostas
Funcionário
1.657 Visualizações
Hello Microsat,
Thanks for reaching out!
Please let us see if we can find this information. We will back to you as soon as possible.
Pedro M.
Tsahi_M_Intel
Funcionário
1.657 Visualizações
Hi Microsat,
I do not want to be wrong here, so i have contacted our HW engineer and will have the exact details.
Thanks for your time,
Tsahi.
Euclid Development Team.
Zhenyu_H_Intel
Funcionário
1.657 Visualizações
For the UART, please refer to /thread/115316 https://communities.intel.com/thread/115316
Funcionário
1.657 Visualizações
Hello Microsat,
These are the connector types used in Euclid:
- UART connector info: Manufacturer: JAE, Part number: DX4R005HJ5
- Power adapter plate interface info: Pogo pins, Pin outs: PAD1---+VBATTERY, PAD2---BATT_ID, PAD3---BATT_GND
And this is the pinout for Euclid's power adapter:
Let us know if this helps.
Pedro M.
DNiel2
Novo colaborador I
1.657 Visualizações
So what the connector for the Power Adapter Plate? The USB Power Cable has a white connector on the end that plus into Power Adapter Plate this is info would be very useful.
Funcionário
1.657 Visualizações
Hi Microsat,
Please let me check more information for the connector for the power plate. I'll get back to you as quickly as I can.
Pedro M.
DNiel2
Novo colaborador I
1.657 Visualizações
I believe that the power plate connector from JST and series GH part number GHR-06V-S and Connector terminal SSHL-002TP0.2
Microsat
Funcionário
1.657 Visualizações
Hi Microsat,
I would like to clarify the following:
Do you need the info for the connector on the power cable or the connector receptable inside the Euclid?
Let me know.
Pedro M.
DNiel2
Novo colaborador I
1.657 Visualizações
Well ether one would work because if I have part number I can look up its mate.
This is kind of info that should be in the manual or the data sheet. In order to make ones own cables or to interface to the Eucid or than from the USB ports.
Funcionário
1.657 Visualizações
Hello Microsat,
We were able to dig up the part numbers. The parts are from Tarng Yu Enterprises. The onboard connector plate is TU1218WNR-NPS-NL-M-A. The cable connector is TU1218HNO-NP.
Let us know if you have any questions.
Pedro M.
Responder
