Items with no label
3338 Discussions
Down-sampling or reduce sampling rate lower than 30 fps
YYun
Does anyone know if there's a way to lower the fps lower than 30 fps? Seems like the low bound is built into the driver or something. Data sheet said 30 or 60 fps but 90 fps also works. Unfortunately, 15 fps did not work for me. Just curious on if there's a way for down-sampling without costing extra CPU.
Hello, @yung.chang:
Could you please provide me with your computer and processor model? Are you trying to achieve this for gaming purposes?
Amy.
Hello, @yung.chang:
I wanted to check on your thread; were to find information in regard to lowering the fps?
Amy.
YYun
Thanks for checking! We were able to solve our problem by adding a medium and voxel filter (we were using ROS) and further down-sampling in the filter.
That is good to hear! If you need further assistance let us know.
Amy.
