Items with no label
3338 Discussões
HELP for build 15063 Creators Update
Funcionário
1.996 Visualizações
I just spent almost 1000 box for a new Envy 17 and right after I bought it the first thing I did is to UPDATE to Creators Update... Suprise surprise... The camera doesn't work anymore and especially the RealSense 300. Is this worth 1000 box??? For me doesn't work even the normal camera so no HELLO... PLEASE HELP!!!
4 Respostas
MartyG
Colaborador honorário III
876 Visualizações
The Creators Update has caused issues with cameras - not just Intel RealSense but with Logitech models of webcams too. Someone else had a problem with the camera on their HP Envy 17 stopping working this week, and they had it fixed by contacting a Microsoft support representative. See the comment at the very bottom of the page in this link:
https://h30434.www3.hp.com/t5/Notebook-Video-Display-and-Touch/Intel-RealSense-Webcam-SR300-disabled-on-HP-ENVY-Notebook/td-p/6070331 Solved: Intel RealSense Webcam SR300 disabled on HP ENVY Notebook af... - HP Support Forum - 6070331
The Microsoft representative fixed it through opening a remote control link to the user's PC and installing files for them. But you could probably do the job yourself using the process described in the comment if you are experienced enough with PC installations.
Funcionário
876 Visualizações
Hello Roope,
Thanks for reaching out!
I understand your situation and how it can be inconvenient. It has been officially noted that the Windows* 10 Creators Update build 15063 is not compatible with the Intel® RealSense™ SR300 camera driver as you can see at https://communities.intel.com/community/tech/realsense/blog/2017/04/07/windows-10-creators-update-build-15063-is-not-compatible-with-intel-realsense-sr300-camera-driver https://communities.intel.com/community/tech/realsense/blog/2017/04/07/windows-10-creators-update-build-15063-is-not-compatible-with-intel-realsense-sr300-camera-driver.
As it is stated in the article above, we are working on the issue but as an immediate workaround, we suggest not to install Windows* 10 Creators Update build 15063 through Windows Update.
I hope this information helps you,
Pedro M.
MHarm1
Principiante
876 Visualizações
MartyG,
Thanks for the post. I'm having the same issue and I downloaded and installed the Intel Chipset Installation Utility and Driver from the HP website as described in your post. It did not appear to resolve my issue, however. Perhaps I need to be patient.
- Mark
MHarm1
Principiante
876 Visualizações
Today I downloaded a Windows 10 driver update that appears to have resolved this issue: "Intel - Image - 5/8/2017 12:00:00 AM - 4.2.159.18". I advise everyone to check for updates and install the driver offered.
Mark
Responder
