Items with no label
3338 Discussioni
Hello at all, I recently bought the intel real sense sr300 and I want to use it with Faceshift. For the sr300 I'm using the intel_rs_dcm_sr300_3.3.27.5718 and sdk (2014) intel_rs_sdk_offline_4.0.0.112526. For faceshift, I m using the version 2015.1.02.
GLuca4
Principiante
1.417Visualizzazioni
Faceshift recognize the cam, but when I start the program the application closes by itself(I think it crashes), in fact the green led of the camera starts and immediately after it turns off. From what might it depend on?
perhaps there is another more recent version of Faceshift? faceshift 2015.2 maybe? Thanks for reply
1 Soluzione
MartyG
Collaboratore onorario III
961Visualizzazioni
The problem with Faceshift is that after Apple purchased the company, it was no longer updated. Also, it commonly stopped working with RealSense after the '2016 R1' RealSense SDK version, which is no longer available.
In your case though, it sounds as though the problem may be that Faceshift is working for you but the connection between the computer and the camera is cutting out as soon as the camera activates. There can be a number of reasons for this, though the most common one is power instability on the USB port (RealSense is very sensitive to the state of the USB port). Plugging the camera into a mains-powered USB hub instead of directly into the PC may help to increase USB camera connection stability.
Alternatively, you could try a newer face morphing product called FaceRig. A free version specially for RealSense is available.
FaceRig
https://store.steampowered.com/app/274920/FaceRig/
IRFaceRig (for RealSense)
https://store.steampowered.com/app/377590/IRFaceRig/
Visualizza soluzione nel messaggio originale
3 Risposte
MartyG
962Visualizzazioni
FaceRig
GLuca4
Principiante
961Visualizzazioni
Thank you Marty, I tried IRFaceRig and it works yes, (without hub). Just for curiosity, what has been the latest version of Faceshift made, before to be bought by Apple?
About faceshift so I think the problem is on fs-1_IntelRealSenseSensorPlugin.dll, maybe
MartyG
961Visualizzazioni
I believe Faceshift 2015.2 was the final version before the Apple purchase.​
Rispondere
