Items with no label
3335 Discussions
Help:get .ply pointcloud from pyrealsense2
York
I have got pointcloud data from only one frame.But I want get pointcloud data from multiple frame.
I know can export .ply file from .bag file by realsense-viewer.So I think maybe by pyrealsense2 it can also come true.
What should I do?
Thanks in advance
The code:
pc = rs.pointcloud()
pc.map_to(color)
points = pc.calculate(depth) # only one frame
points.export_to_ply("xxx", color)
MartyG
You could try converting the script below from an Intel point cloud tutorial for Python, which uses 'color_frame' and 'depth_frame' instead of 'color' and 'depth'.
pc = rs.pointcloud();
pc.map_to(color_frame);
pointcloud = pc.calculate(depth_frame);
pointcloud.export_to_ply("1.ply", color_frame);
cloud = PyntCloud.from_file("1.ply");
cloud.plot()
Here's the link to the full tutorial.
https://github.com/dorodnic/binder_test/blob/master/pointcloud.ipynb binder_test/pointcloud.ipynb at master · dorodnic/binder_test · GitHub
York
Hi MartyG,
Thanks for your reply.
I use 'color' and 'depth' which are just different names, I know they are got from frames.
I just want to know how to export .ply file with multiple frame.
Is there a function to achieve this?
Thank you
MartyG
The 'export_ply_example' sample program for Python may meet your needs.
https://github.com/IntelRealSense/librealsense/blob/master/wrappers/python/examples/export_ply_example.py librealsense/export_ply_example.py at master · IntelRealSense/librealsense · GitHub
York
Thank you for your warm reply.
I had seen the link several times.There is no usefule infromation about how to export .ply file from multple frames.
Maybe there is no function to achieve this in pyrealsense2.
MartyG
There is another Python script in the link below for generating a point cloud and saving it as a ply. Is there anything in it that is helpful to you?
Hi York_,
You should use a loop around your code like this:
while True:
# Wait for a coherent pair of frames: depth and color
frames = pipeline.wait_for_frames()
depth_frame = frames.get_depth_frame()
color_frame = frames.get_color_frame()
Alexandra
York
Thers is still no useful information.
Thank you.
York
In this way, when 'pc.calculate(depth_frame)', there is also only one frame in it, right?
York
Just now,I found that the .ply file exported from realsense-viewer just have one frame data.
It can export different .ply with different time in the .bag file from realsense-viewer.
So maybe it can't export .ply containing multiple frames.
These two pictures are different.
York
So I think D435 can't shoot panorama point cloud(the whole room), or panorama requires manual synthesis, right?
MartyG
I will let Alexandra continue with the ply question when she is back on the forum, as I do not have any information to add about that.
Regarding D435's viewpoint ... though the D435 has a wide field of view (FOV), you would have to either arrange multiple cameras around the room or walk a single camera around the room to capture all of it.
In a "volumetric capture" demo Intel did with D435s in January 2018, four cameras were used to capture a 180 degree view. It was estimated that eight would be needed in that setup for 360 degrees (though the company Jaunt managed a 360 degree view with six cameras).
https://realsense.intel.com/intel-realsense-volumetric-capture/ Volumetric Capture @ Sundance using Intel RealSense Depth Cameras
York
Thank you very much.
Now I have some clarity about this.
In this way, if I need a .ply include the whole room point cloud, like a whole scene of ScanNet-data, I need to synthesize one by one frame by myself.
It should be so.
