Items with no label
3338 Discussions
How do I generate a Pointcloud
I would like to generate a pointcloud, like in ROS sensor_msgs/PointCloud2. Any pointers would be welcome. Otherwise, I'll post any progress I make towards this in this thread.
MartyG
Could you tell us please whether you are using the RealSense SDK with Windows or the Librealsense SDK with Linux please? Thanks!
I'm using and Euclid running ROS, so it's librealsense. I see that '/camera/depth/points' is in the 'rostopic list' so I expect that I'll need to write a node that subscribes to this.
MartyG
Here is a script for a Librealsense tutorial example for generating a point cloud. I hope it will be of use to you.
https://github.com/IntelRealSense/librealsense/blob/master/examples/cpp-tutorial-3-pointcloud.cpp librealsense/cpp-tutorial-3-pointcloud.cpp at master · IntelRealSense/librealsense · GitHub
Amit_M_Intel
That's right.
you can simply register to that topic and get the generated pointcloud.
Marty's answer is correct if you do not want to use ROS.
