Items with no label
3338 Discussions
Intel SR300 DCM failed to detect an Intel® RealSense™ 3D camera
EBrou
Débutant
10 655 Visites
I know the Depth function for SR300 will not work on Windows 10 Creators Update (/community/tech/realsense/blog/2017/04/07/windows-10-creators-update-build-15063-is-not-compatible-with-intel-realsense-sr300-camera-driver https://communities.intel.com/community/tech/realsense/blog/2017/04/07/windows-10-creators-update-build-15063-is-not-compatible-with-intel-realsense-sr300-camera-driver). However, I'm not able to install the DCM. It fails with this error:
I can't conclude that this is the same issue therefore I'm asking for some help here.
Here's the 2 event in the Windows Event Viewer:
Event 1
Faulting application name: FWUpdateSR300.exe, version: 3.3.27.5718, time stamp: 0x57e3cfa2
Faulting module name: IVCAM1_5.dll, version: 3.6.13.0, time stamp: 0x57d83634
Exception code: 0xc000001d
Fault offset: 0x000e2e61
Faulting process id: 0x20d4
Faulting application start time: 0x01d2cf481dac71c0
Faulting application path: C:\Temp\INTEL\plugins\FWUpdateSR300\FWUpdateSR300.exe
Faulting module path: C:\Temp\INTEL\plugins\FWUpdateSR300\IVCAM1_5.dll
Report Id: 2e31c415-e8a9-4262-9a4d-58b4205bc611
Faulting package full name:
Faulting package-relative application ID:
Event 2
Windows cannot access the file for one of the following reasons: there is a problem with the network connection, the disk that the file is stored on, or the storage drivers installed on this computer; or the disk is missing. Windows closed the program Intel(R) RealSense(TM) SR300 FW Update Tool because of this error.
Program: Intel(R) RealSense(TM) SR300 FW Update Tool
File:
The error value is listed in the Additional Data section.
User Action
1. Open the file again. This situation might be a temporary problem that corrects itself when the program runs again.
2. If the file still cannot be accessed and
- It is on the network, your network administrator should verify that there is not a problem with the network and that the server can be contacted.
- It is on a removable disk, for example, a floppy disk or CD-ROM, verify that the disk is fully inserted into the computer.
3. Check and repair the file system by running CHKDSK. To run CHKDSK, click Start, click Run, type CMD, and then click OK. At the command prompt, type CHKDSK /F, and then press ENTER.
4. If the problem persists, restore the file from a backup copy.
5. Determine whether other files on the same disk can be opened. If not, the disk might be damaged. If it is a hard disk, contact your administrator or computer hardware vendor for further assistance.
Additional Data
Error value: 00000000
Disk type: 0
I tried to run the FWUpdater seperatly command : FWUpdateSR300.exe -oemId:0xcafecafe -force but keep getting this error:
In the Windows device manager everything seems fine:
The computer is a fairly new Pentium G4600 on a B250 chipset and 16gb of ram. I don't think it's a CPU or motherboard compatibility issue hence I'm all out of wits.
Cheers!
Étienne
0 Compliments
19 Réponses
ZPawl
6 851 Visites
I have same problem with Razer Stargazer. This both use same Intel RealSense 3D SR300 camera panel.
- that's all they said. I have same issues.
0 Compliments
Employé
6 851 Visites
Hi guys,
Thanks for interested in the Intel® Realsense™ Platform.
The reason why you are not able to install the DCM is because the Depth Camera Manager doesn't recognize your Camera drivers, like the announcement states ( ) the RGB functions may work normally, but it's not guaranteed.
We would encourage you to downgrade your Windows version in order to be able to use again your SR300.
We apologize for any inconvenience that this may cause.
-Jose P.
EBrou
Débutant
6 851 Visites
Unfortunately, that's not gonna cut it. There are features from the Creator Update that we'll use and therefore we'll wait for an updated driver which fixes the issue. Is there an estimated ETA? It's not like the Creator Update was such a surprise for anyone out there and that as far as I know, the problem is far from new.
Étienne
0 Compliments
GMorg3
6 851 Visites
Really? That is your explanation? Let me clue you in on something. Until the 5/8/17 drivers were released, my cam worked fine on 16193. Which is a Redstone 3 build. So I do not know where you got your information. But it is wrong. And it does work on Creators Update.
0 Compliments
Employé
6 851 Visites
Hi guys,
I understand that it is frustrating, if I were in your position I would probably feel the same way. I just wanted to let know that a possible workaround has been published in the Realsense Forum ( ), the announcement points to a thread ( ) created by Slothameedees where he shares the steps that he followed in order to fix this issue.
-Jose P.
0 Compliments
MWald3
6 851 Visites
Yes I went through that step by step. I know that it worked for that person on 3 PC's. But I tried it five times on ONE PC and still didn't get it to work...
So What's the current status on this issue? Is it a high severity issue or low?
0 Compliments
Employé
6 851 Visites
Hi MatthewW,
I'm sorry to hear that the workaround didn't work for you. This is a high priority issue to us, our Engineers are working diligently in order to fix this issue.
We appreciate your patience.
-Jose P.
0 Compliments
MWald3
6 851 Visites
Now I think it's beyond operational status. Now I have tried the camera on 2 machines and a Virtual Machine, and it won't activate. All because I tried to update the firmware like it said in that post.
Good lord, what have I done?
0 Compliments
MWald3
6 851 Visites
0 Compliments
MWald3
6 851 Visites
Ok, I am not one to give up easily. So.. I made a total backup of my Current Drive C. Reformatted and reinstalled 15063 (Creator's Update) from scratch.
Lookee what I see, Virtual Driver! Awesome. Next we try to play some video on it.,
Do you see what I see? My snacks. so this works on Creator's update. Now let's break it.
I have NOT turned on the option for "Give me updates for other Microsoft Products when I update Windows" yet. That's in a minute. Restart after the updates. OK.
Creating another reply Part 2
0 Compliments
MWald3
6 851 Visites
Reboot and look what version we have now and ... The virtual Driver is STILL THERE!
We turn on the option:
I'm sure within a few days or less there will be an update that shows the Intel - Image from 5/8/2017.
And shortly afterwards look:
Looks like we have a Depth driver just got installed.. let me reboot and see if it's trashed.
Before: and After in Part 3
0 Compliments
MWald3
6 851 Visites
Part 3 is a reboot and still working. But I fear an update will make it not work again.. Stay Tuned.
0 Compliments
Employé
6 851 Visites
Hi MatthewW,
Thanks for sharing your results! It will be useful for other members in the community.
We will let you know for any update developments regarding this issue.
-Jose P.
0 Compliments
EBrou
Débutant
6 851 Visites
Unfortunately, no, this doesn't work.
The issue is not resolved.
0 Compliments
Employé
6 851 Visites
Hi EtienneB,
Yes, we are aware that this is issue is not solved yet. At the moment, we have only shared workarounds, so they may or may not work. As soon as we have this issue solved, we will be making an announcement in the Realsense community.
Thanks for your understanding.
-Jose P.
0 Compliments
GMorg3
6 851 Visites
DO make it sooner than later. No excuse whatsoever for people to be having this issue. None! Get this taken care of.
"This message was posted on behalf of Intel Corporation
Hi EtienneB,
-Jose P."
0 Compliments
JTees1
Débutant
6 851 Visites
This is still happening. My machine just updated to Creators update and then boom camera did not work. It wont let me reinstall the driver as it tries to update camera firmware and fails. Anyone got around this problem?!
0 Compliments
MWald3
6 851 Visites
Really, that's the OFFICIAL statement?
Tell me oh Intel technicians, Why the camera was working since End of March PERFECTLY until yesterday when a driver:
Disabled the camera yesterday. Feel free to take your time fixing it, as we all send our cameras back and get on Social Media "Praising" your accomplishments.
Not cool. If it's not broken, don't fix it.
0 Compliments
MWald3
6 851 Visites
And here it is, 3 weeks later.
Still working. But in many cases a fresh install isn't an option.
0 Compliments
Répondre
