Items with no label
3338 Discussions
Is there an unstated minimum graphics requirement to run the ReaSense SDK demos?
DUchi
I have an Acer E5-575 (core i5 7200U, 12Gig memory, USB3, Intel 620 graphics, Win10) but it won't run the SDK demos, even if the SR300 is externally powered. As soon as I try to use the SR300, I get a zero to a few frames of video and then a "disconnect" beep. The program terminates and I get a reconnect beep. However if I select "Raw Streams" and only use video, it works. If I select Depth or IR (alone or in combination) it aborts. Is there some reason the Intel 620 graphics will not work with the SDK demos?
Hi Modeler,
Do you have updates on this case? Were you able to test our suggestions?
Pablo M.
