Hi AAbde10,
This forum is for Intel RealSense cameras. Problems with Intel Anti-Theft are usually posted on the Processors forum.
https://forums.intel.com/s/topic/0TO0P00000018NWWAY/processors
Here are a couple of past discussions from the Intel forums about Intel Anti-Theft that you can try though.
https://forums.intel.com/s/question/0D50P0000490Ks2SAE/intel-antitheft
https://forums.intel.com/s/question/0D50P00004908zGSAQ/intel-antitheft-problems-please-help
You will probably not be able to do much unless you have the Anti Theft account password for the computer though.
McAfee's guide to the software says that you can access the web console by using an unlocked computer (or whatever internet-capable device you used to post this message) to go to https://home.mcafee.com and then login to the McAfee account and select the computer with Anti-Theft installed. Then click 'Go To Web Console' in the McAfee Anti-Theft section.
The full guide can be found here:
https://service.mcafee.com/webcenter/portal/cp/home/articleview?articleId=TS101587
链接已复制
Hi AAbde10,
