Items with no label
3338 讨论
On the Linux development board, when I made cmake, the download of FW failed.
fqing1
初学者
2,794 次查看
Cache_-793dbcabd4809465..jpgI tried it on several boards. This is a recent problem.
0 项奖励
1 解答
Eliza_D_Intel
员工
1,078 次查看
Hello fqing1,
Thank you for your interest in the Intel RealSense Products.
Please make sure that you build Librealsense with BUILD_WITH_TM2=FALSE and you will no longer receive this error message.
Eliza
在原帖中查看解决方案
4 回复数
Eliza_D_Intel
员工
1,079 次查看
Hello fqing1,
Eliza
fqing1
初学者
1,078 次查看
Thanks,Eliza. According to your guidance, the effect is very good.And I found no such problem with the latest version.
0 项奖励
fqing1
初学者
1,078 次查看
Best wishes to you, thank you again!
FengQingwei,from Qingdao,China.
0 项奖励
fqing1
初学者
1,078 次查看
Thank you for your kind answer,Eliza. The problem has been solved very well. Best wishes to you. FengQingwei.
0 项奖励
回复
