Items with no label
3338 Discussions
Point Clould Question ZR300
AJina
Hello I'm using the ZR300. I'm trying to a develop a program where you can click on a pixel in stream from the zr300(color/ir) and then get the x, y, z in real world coordinates.
Using the tutorial cpp-pointclould. I want to get a specific pixel and find it's coordinates in x,y,z in meters. These two lines I think can help.
rs::float2 depth_pixel = {(float)dx, (float)dy};
rs::float3 depth_point = depth_intrin.deproject(depth_pixel, depth_in_meters);
Can I just replace the dx and dy with a pixel location on the ir or color image? Is it possible to get the x y z from that pixel by plugging in it's location into that dx, dy. Then read out the real world coordinates with depth_point.x/y/z?
Akash Jinandra
Hi Akash,
Thanks for your interest in the Intel RealSense Technology.
It seems that the "deprojec" API is now obsolete and has been replaced with rs_deproject_pixel_to_point. I would like to share this document that may help you with your implementation: https://github.com/IntelRealSense/librealsense/blob/f482fc3a9bb13d3ea09a567294131073877087ee/doc/projection.md https://github.com/IntelRealSense/librealsense/blob/f482fc3a9bb13d3ea09a567294131073877087ee/doc/projection.md.
Hope you find this information useful.
Kind Regards,
-Yermi A.
Hi Akash,
Kind Regards,
-Yermi A.
AJina
Hi Yermi,
I was wondering if there is any example code using the rs_deproject_pixel_to_point? The API gives some hints, but unless I see it in action, I'm not sure how it actually could be implemented
