Items with no label
3341 Discussions
Questions for the Intel RealSense SDK Java/Processing wrapper
GProf
I've just started playing with the F200 camera and I have a few initial questions as I began with the Java Wrapper:
  1. Is the Processing Wrapper the same thing as the Java library ? (It appears this way, but I could use a confirmation)
  2. How can I retrieve the Face landmarks using Java ? (snippet bellow)
  3. Can I use the heart rate features in Java ? If so, how ?
  4. Can I use the BlobModule in Java ? If so, how ? (snippet bellow)
  5. Where can I get an updated documentation (including what's currently supported or not in Java) ?
For Issue 2, retrieving facial landmarks, I've tried using both the non-grouped and grouped methods:
int npoints = detectData.QueryNumPoints();
PXCMFaceData.LandmarkPoint[] points=new PXCMFaceData.LandmarkPoint[npoints];
detectData.QueryPoints(points);
println(points);
This returns an empty list, similar to retrieving grouped points (which returns true):
int numPtsLE = detectData.QueryNumPointsByGroup(LandmarksGroupType.LANDMARK_GROUP_LEFT_EYE);
LandmarkPoint[] ptsLE = new LandmarkPoint[numPtsLE];
boolean hasLEPoints = detectData.QueryPointsByGroup(LandmarksGroupType.LANDMARK_GROUP_LEFT_EYE,ptsLE);
if(hasLEPoints){
for(int le = 0; le < numPtsLE; le++){
if(ptsLE[le] != null) ellipse(ptsLE[le].image.x,ptsLE[le].image.y,3,3);
println(hasLEPoints);
println(ptsLE);
prints
true
[0] null
[1] null
[2] null
[3] null
[4] null
[5] null
[6] null
[7] null
[8] null
When setting up, I've enabled landmark using the PXCMFaceConfiguration instance:
faceConfig.landmarks.isEnabled = true;
For issue 3, using hearRate, calling QueryPulse as the documentation suggests
// cfg is a PXCMFaceConfiguration instance
cfg.QueryPulse().Enable();
ends up with a NullPointerException
Exception in thread "Animation Thread" java.lang.NullPointerException
at intel.rssdk.PXCMFaceConfiguration$PulseConfiguration.Enable(PXCMFaceConfiguration.java:335)
I was expecting to write something like
faceConfig.pulse.isEnabled = true;
but pulse doesn't appear to be a property of PXCMFaceConfiguration
For issue 4, using the Blob Algorithm, I tried following the documentation:
// Create an instance of the SenseManager
PXCMSenseManager sm = PXCMSenseManager.CreateInstance();
// Enable the blob module
sm.EnableBlob();
// Get an instance of PXCMBlobModule
PXCMBlobModule blobModule = sm.QueryBlob();
but EnableBlob() isn't present. I'm guessing EnableModule(int,ImplDesc) might work,
but I'm not sure what arguments to pass. Again, QueryBlob() is missing (perhaps QueryModule(int) should be used) ? If so, how ?
Regarind issue 5, I'm trying to use as the SDK as much I can, but it would be a huge time saver
knowing what I can an can not use for now (and when to expect currently unsupported features).
I am using the latest Intel RealSense Drivers and SDK AFAIK:
Intel RealSense Depth Camera Manager F200 1.3.20.55679
Intel RealSense SDK 2014 5.0.3.187777
on Windows 8 (version 6.2, build 9200)
Thank you,
George
Not applicable
Intel® RealSense requests are supported by our software department. Please resend your request using the forum below.
https://software.intel.com/en-us/Forums/realsense Intel® RealSense™ SDK
There are more support from the main page Intel® Developer Zone.
https://software.intel.com/en-us/RealSense/Coding RealSense - Coding | Intel® Developer Zone
Mike C.
Not applicable
Mike C.
GProf
Ooops, my bad! I got the wrong forum, I thought I was on the Intel RealSense SDK forum.
I have posted https://software.intel.com/en-us/forums/topic/562082 there as well.
(Please feel free to remove this post (as it's now crossposted to the SDK forum).
Thank you,
George
