Items with no label
3338 Discussions
RealSense D435 No Frames Received in Stereo Module Depth Stream
LKlot
Hello!
First time using my RealSense D435 camera.
I am getting a "No Frames Received!" message in the Depth Stream of the Stereo Module in the Intel RealSense Viewer.
The IR and RGB streams work.
Any ideas on how to resolve this?
Windows 10 Version 1709 (OS Build 16299.125)
USB 3.0 via PCI Card
Depth stream seems to work when I run rs-align.exe.
MartyG
If the RS_Align sample is working fine for you, I wonder if you are experiencing a Known Issue in the release notes for the 2.10.0 SDK that is specific to the RealSense Viewer program.
"Realsense Viewer is not streaming after wake up from sleep mode (DSO-8094)"
