Items with no label
3338 Discussões
Recommended USB3 extension cables for ZR300 and other RealSense devices?
KChun10
Principiante
2.464 Visualizações
Hi famed RealSense community,
Want some advice here as the included cables for the ZR300 are waaaay too short (i.e. barely a foot). I believe you need a cable that can handle power, so maybe that explains the short size but I run into problems trying to mount this camera with the short cable. My hope is someone can guide me on an extension cable or something that's maybe 6/10 feet USB3 cable that works reliably. I want to spend my money judiciously.
Any clues?
Ciao
-rg
3 Respostas
Funcionário
1.095 Visualizações
Hello RollerGirl,
Thank you for your interest in the Intel® RealSense™ Camera ZR300.
I'm sorry to hear that the cable provided doesn't seem to be suiting your needs.
The fact is that I haven't used another cable, so I can't personally recommend an alternative. Also, you have to take into account that the cables provided are the ones that have been officially tested by Intel, so even if another community member provides a suggestion, there is no guarantee that the device will operate as expected.
If you have any other question or update, don't hesitate to contact us.
Have a nice day.
Andres V.
MartyG
Colaborador honorário III
1.095 Visualizações
Andres is correct in his advice that the provided cable has been specially rated for use with the RealSense camera. Having said that, if you want to take the risk of purchasing a longer cable then the best results with other RealSense camera models has been with a 1 m cable. This is because the camera's signal gets lost over a long cable. The majority of people in the past who used a 2 m cable failed to get the camera to work with it, though there was a couple of cases where people got it working with a more expensive 2 m cable (i.e a high-end, well made one rather than a budget one).
ALi11
Principiante
1.095 Visualizações
We have been providing USB 3.0 extension solution for many real sense users.
Our https://www.newnex.com/usb-3-cables.php# USB3StraightAtoMicroB passive cable can go up to 16.4 ft. (5 meters).
https://www.newnex.com/firenex-ulink-usb-3-active-repeater-cable.php Active extension cable can go up to 50 ft. (20 meter)
https://www.newnex.com/usb-3-1-optical-fiber-extender-repeater.php Fiber Extender can go up to 1000 ft (300 meter)
Responder
