Items with no label
공지
3338 토론
Retrieving depth information from ZR300
nnain1
새로운 기여자 I
2,500 조회수
I used ZR300 for depth measurement.
I can't retrieve correct Depth matrix from the camera.
What I did was as follow and retrieve the depth matrix from the stream.
const uint16_t * depth_image = (const uint16_t *)dev->get_frame_data(rs::stream::depth);
float scale = dev->get_depth_scale();
float data[HEIGHT*WIDTH];
for(int dy=0; dy
for(int dx=0; dx
uint16_t depth_value = depth_image[dy * depth_intrin.width + dx];
if(depth_value == 0)
continue;
else
data[dy*dx] = (float)depth_value * scale;
Mat depthimage(HEIGHT, WIDTH, CV_32FC1, &data);
Mat colorimage(HEIGHT, WIDTH, CV_8UC3, (uchar*)dev->get_frame_data(rs::stream::color));
imshow("dst", depthimage);
waitKey(1);
dst.release();
I have another depth follow sample from realsense, that has correct object.
The code is
glPixelTransferf(GL_RED_SCALE, 0xFFFF * dev->get_depth_scale() / 2.8f);
glDrawPixels(WIDTH, HEIGHT, GL_RED, GL_UNSIGNED_SHORT, dev->get_frame_data(rs::stream::depth));
glPixelTransferf(GL_RED_SCALE, 1.0f);
Red color image is the one following sample program and the image "dst" is the one using the first code.
Another one is the color image, we can see there is a cabinet.
Why I don't have correct depth image, what is wrong with my code?
0 포인트
6 응답
직원
1,174 조회수
Hello inmn,
Sorry for the late response. While we don't usually debug customer's code, I am trying to reproduce your issue but have encountered some obstacles. Please stay tuned...
Jesus
Intel Customer Support
0 포인트
직원
1,174 조회수
Hello inmn,
It seems that you have to do a conversion of the pixel formats from RealSense to OpenCV. See the file https://github.com/IntelRealSense/realsense_sdk_zr300/blob/master/sdk/src/core/image/image_conversion_util.cpp for an example of how to do this.
Let us know if this helps.
Jesus
0 포인트
nnain1
새로운 기여자 I
1,174 조회수
Hello Jesus,
Many thanks for the reply.
I have the same issue for color image. I tried to grab into Opencv's Mat image.
What I did was
dev.enable_stream(rs::stream::color, 640, 480, rs::format::bgr8, 60); cv::Mat colorImg(480, 640, CV_8UC3, (unsigned char *)dev.get_frame_data(rs::stream::color)); imshow("colorImg",colorImg); cv::waitKey(1);
Then my color image became. Is that the same issue as I need to pixel format conversion?
0 포인트
nnain1
새로운 기여자 I
1,174 조회수
Can I have any sample of usage?
0 포인트
nnain1
새로운 기여자 I
1,174 조회수
Thanks now ok.
I take the image as rgb8
dev.enable_stream(rs::stream::color, 640, 480, rs::format::rgb8, 60);
Then convert to RGBtoBGR
cv::cvtColor(srcMat, grayMat, CV_RGB2BGR);
It works.
0 포인트
nnain1
새로운 기여자 I
1,174 조회수
Hello Jesus,
What I did was
0 포인트
응답
