Items with no label
3338 Discussões
SR300 Depth Display Cutoff
EPaul1
Principiante
1.527 Visualizações
Below is the stream coming from sr300 depth display(at ~.6 meters) executable. The image is rounded off, which causes problems for image analysis. I have worked with a few different depth sensors before and haven't encountered this problem. Is this something that is unique to the sr300 design that cannot be changed or is there some switch that I can use to see the edges of the image?
Thanks in advance
1 Solução
MartyG
Colaborador honorário III
578 Visualizações
The SR300's default maximum scan range is just 1.5 m. This can be extended to 4 m with scripting at the cost of image quality, which may improve your results.
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v2016r3/documentation/html/index.html?ivcamfilteroption_device_pxccapture.html Intel® RealSense™ SDK 2016 R3 Documentation
Ver solução na publicação original
1 Responder
MartyG
579 Visualizações
Responder
