Items with no label
3338 ディスカッション
SR300 doesn't work
音音
ビギナー
13,627件の閲覧回数
i can't use SR300.
Please watch the images.
The picture is dark.
Other camera is working.
When I use Xsplit.
Other camera works.
Ther is no problem in my PC's Spec.
Windows 10 Pro 64bit
Intel(R) Core(TM) i7-4960X CPU @ 3.60GHz 3.60GHz
64.0GB RAM Memory
NVIDIA GeForce GTX TITAN Black
I'm not using SR300 for any other program at the same time.
I already installed these.
https://software.intel.com/en-us/intel-realsense-sdk/download https://software.intel.com/en-us/intel-realsense-sdk/download
intel_rs_dcm_sr300_3.3.27.5718
intel_rs_sdk_mw_core_offline_11.0.27.1384
intel_rs_sdk_mw_cursor_hybrid_11.0.27.1404
intel_rs_sdk_mw_face_hybrid_11.0.28.2787
intel_rs_sdk_mw_hand_hybrid_11.0.27.1404
intel_rs_sdk_mw_scan3d_hybrid_11.0.27.8892
intel_rs_sdk_mw_seg3d_hybrid_11.0.27.2322
but SR300 doesn't work.
What should I do?
0 件の賞賛
40 返答(返信)
MartyG
名誉コントリビューター III
6,223件の閲覧回数
To clarify: what Oto is doing above is showing how the SR-300 camera does not generate a picture, but another type of camera does (Microsoft Lifecam). He is not running two SR-300 cameras on the same computer.
Oto, if you have the SDK and DCM installed and they appear to be working, then the next question that I would ask is: are you using Windows 10 Insider Preview build 14986, 15002 or 15007? RealSense cameras and the Windows Hello login are currently not working in these Insider builds.
If you are not using one of these Insider builds for your Windows 10, the next thing I would check is if the camera's green light on its front panel is lit when you are trying to use the camera.
音音
ビギナー
6,223件の閲覧回数
Thank you for the reply.
My Windows10 is 10.0.14393.
And the green light doesn't lit when I use Xsplit and AG-Web.
But the green light lit when I set up the Windows Hello.
Though the picture of my face was not displayed.
MartyG
名誉コントリビューター III
6,223件の閲覧回数
Someone on this forum had a problem with their camera using Build 14393 six days ago. In their case, the DCM would not install because their camera was not being detected.
I think that with any problem with the camera where a recent Windows Insider build is being used, that may be a strong candidate for the cause of the problem. Whilst the majority of RealSense camera failure reports started with Build 14986, there have been occasional reports of problems going as far back as Build 14257.
従業員
6,223件の閲覧回数
Hi Oto,
Thanks for your interest in the Intel Realsense Platform.
Analyzing your computer specs, we see that your computer doesn't meet the hardware requirements for the SR300 (http://www.intel.com/content/www/us/en/support/emerging-technologies/intel-realsense-technology/000020964.html System Requirements for Intel® RealSense™ Camera SR300 ), see your processor generation.
Still there are some cases where the camera works, please follow MartyG suggestions.
We will be waiting for your reply, have a nice day!
-Jose.
音音
ビギナー
6,223件の閲覧回数
Hi, thanks for the reply.
My CPU is 4960x.
Do you mean I have to change the CPU to 7700k or something?
4960x was very expensive.
I don't wanna change this.
Can't I use SR300 with 4960x?
MartyG
名誉コントリビューター III
6,223件の閲覧回数
It looks like Core i7-4960X is a third generation Ivy Bridge processor. The minimum spec for the SR-300 is a sixth generation Skylake processor. Even the SR-300's predecessor the F200 had a fourth generation Haswell processor as its minimum spec.
Your options are therefore very limited. An old processor is not completely useless with the camera - they can sometimes be used for simple tasks such as RGB video or processing raw camera data - but for the most part you won't be able to access anything like the full potential of the RealSense camera.
The cheapest option for getting Skylake would probably be just to buy a Skylake PC rather than try to buy parts and fit them to an existing machine. Intel is now up to 7th generation Kaby Lake, with 8th generation Coffee Lake coming up after that in 2017. So as Skylake is "old tech" now even though it's only been out a couple of years (CPUs move so fast!), a Skylake PC would probably be quite affordable now. Of course, affordable is relative to how much money you have
I hope you find a solution that works out for you.
音音
ビギナー
6,223件の閲覧回数
Thank you.
OK, I will buy the new CPU.
Hello.
I bought new Motherboard and CPU and Memory.
Motherboard
https://www.asus.com/Motherboards/ROG-STRIX-Z270G-GAMING/ ROG STRIX Z270G GAMING | Motherboards | ASUS Global
CPU
https://www.amazon.com/Intel-Desktop-Processor-i7-7700K-BX80677I77700K/dp/B01MXSI216 https://www.amazon.com/Intel-Desktop-Processor-i7-7700K-BX80677I77700K/dp/B01MXSI216
Memory
https://www.amazon.com/gp/product/B016ORTNI2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B016ORTNI2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
This is my spec.
Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz 4.20GHz
64.0GB RAM Memory
I installed all the drivers.
http://www.intel.com/content/www/us/en/support/emerging-technologies/intel-realsense-technology/intel-realsense-cameras.html Intel® RealSense™ Cameras
https://software.intel.com/en-us/intel-realsense-sdk/download Intel® RealSense™ SDK | Intel® Software
But I still can't use SR300.
The camera is green of only 640x480.
Is there still something I have to do?
MartyG
名誉コントリビューター III
6,223件の閲覧回数
Your new processor is the current 7th generation Kaby Lake. SR300's specification only needs a 6th generation Skylake as a minimum. So you are fine now with the processor. So that isn't likely to be the problem. Likewise, you have Windows 10, so that is fine too, and your Titan graphics is more than enough to run RealSense well.
Usually, if you get a low resolution like 640x480 on your computer then it means that the drivers for your graphics card are not installed. If this is the case then you should download and install the latest drivers for your Titan card. You may have got an installation dvd with your Nvidia card that you can use to install the driver.
If you do not have an installation dvd, you can download the driver via the Nvidia Experience interface.
Edit: I should add that if you have rebuilt your PC and done a clean re-install of Windows 10, it may look as though your graphics are working. But if you have not re-installed the drivers for your graphics card then the PC uses its own integrated graphics chip on the motherboard instead. This makes the Windows desktop look okay, but when you go to run a program when you need to choose a high graphics resolution, you find that the options to do so are missing.
音音
ビギナー
6,223件の閲覧回数
After I exchanged the Motherboard and CPU and Memory,
I did the clean install of Windows7, and then I upgraded to Windows10.
That was yesterday.
And now, I installed the new driver for my TITAN
"378.49-desktop-win10-64bit-international-whql",
but nothing changed.
When I choose the
"Intel(R) Realsense(TM) Camera SR300 RGB",
the picture is dark and the SR300's green light doesn't lit.
And I can choose the resolution 1920x1080 and etc.
When I choose the
"Intel(R) Realsense(TM) Camera SR300 Depth",
the picture is green and the SR300's green light lits.
And I only can choose the resolution 640x480.
Is there any hint to solve this problem?
MartyG
名誉コントリビューター III
6,223件の閲覧回数
I did not know you were using a program called Facerig until I looked at the full size pictures. I wondered why I had not seen the program in your pictures before! So it is not a program that came packaged with the SDK. I did some research on it, and it is not just you. Other people have had their resolution set to 640x480 too. It apparently happens because the resolution settings of Facerig get corrupted on start up of the program and it reverts to 640x480.
The creators of Facerig says: "A small workaround to this is to go to Documents\Holotech\FaceRig\UserCfg\ and open config.usc with a text editor, then change the values for r_width to 1920 and r_height to 1080 and see if the save gets corrupted again."
Also, apparently Facerig does not support RealSense by default, and you need to download and install a free plugin to give it RealSense compatibility.
http://store.steampowered.com/app/420824/?snr=1_5_1100__1100 FaceRig support for Intel® RealSense™ on Steam
And there is a free version of Facerig called IR Facerig that is designed to work only with RealSense.
https://facerig.com/irfacerig/ https://facerig.com/irfacerig/
音音
ビギナー
6,223件の閲覧回数
Thanks for the reply.
But Facerig has nothing to do with this problem.
This is Webcamera software.
Choosing "Depth".
Image is green.
This is Xsplit.
I can choose only "RGB".
I don't know why.
And the image is dark.
SR300's green light doen't lit.
This is the setup window of Windows Hello.
The image is white but it basecally transmit the picture, means my face.
I think it is the problem of SR300.
MartyG
名誉コントリビューター III
6,223件の閲覧回数
XSplit and AG-Web record RGB video. They do not use RealSense functions such as depth and infra-red and are just using the RealSense camera as an ordinary webcam. So I would not expect them to offer more than just an RGB option. If you are choosing Depth in AG-Web then you are giving it data from the camera's depth analysis camera that it cannot process, as it is not programmed for depth data (which is not the same thing as a video picture). You should be choosing 'Intel RealSense Camera SR300 RGB'.
Still, the camera's green light should come on when using RGB webcam video in XSplit (I know this because I use XSplit with my F200 camera myself).
音音
ビギナー
6,223件の閲覧回数
My SR300 doesn't work even as an ordinary webcam.
It shows nothing but dark.
These are pictures when I'm choosing RGB.
When I'm choosing RGB, SR300's green light doesn't lit.
The point is, SR300 is not working when it's RGB.
Isn't there any method to find the cause of this trouble?
I uploaded the video that i'm trying to use SR300.
https://www.youtube.com/watch?v=Q_qt-StO1d8 SR300 - YouTube
MartyG
名誉コントリビューター III
6,223件の閲覧回数
There is a camera testing program called Camera Explorer. You can find it if you type the word camera into the 'Ask me anything' box on the bottom of Windows next to the button where you shut the computer down. This programs lists the RealSense cameras you have attached to your computer.
If you click on one of the listed cameras then it brings up a testing program.
音音
ビギナー
6,223件の閲覧回数
Thank you for the information.
I tried it.
https://www.youtube.com/watch?v=xKngA5gDN-4 https://www.youtube.com/watch?v=xKngA5gDN-4
By the way, isn't there any other camera we can buy now that is using RealSence?
Is SR300 the only one?
SR300 is so unstable and I even can't find what the cause is.
MartyG
名誉コントリビューター III
6,223件の閲覧回数
Thanks for the video. Sorry that it still is not working for you.
There are two new RealSense camera due to be released this year, the ZR-300 and the R400. There is currently no release date for them yet though, so until then SR-300 is the newest camera available.
https://newsroom.intel.com/chip-shots/intel-announces-tools-realsense-technology-development/ Intel Announces Tools for RealSense Technology Development | Intel Newsroom
音音
ビギナー
6,223件の閲覧回数
Is there possibility of initial failure of SR300?
MartyG
名誉コントリビューター III
6,223件の閲覧回数
If you bought your camera from Intel's web store and you still have its box and the other bits that were in the box when you bought it, you can return it to Intel to get a replacement camera.
If you did not buy it from Intel, you should talk to the place that you bought it from about a replacement.
音音
ビギナー
6,223件の閲覧回数
Before the replacement, can you tell me the drivers I need to install concretely?
I installed these.
Are these right?
MartyG
名誉コントリビューター III
6,196件の閲覧回数
Those look fine. If you wanted to get a video picture displayed, the only ones you needed were intel_rs_dcm_sr300_3.3.27.5718 (DCM) and intel_rs_sdk_mw_core_offline_11.0.27.1384 (Essentials).
Even if the DCM wasn't working, you should still have been able to get an ordinary RGB video picture in your video recording applications such as AG_Web and XSplit, since the PC treats the RealSense camera like an ordinary webcam if the RealSense files are not working properly. This is because the camera's drivers are installed when you install the DCM.
You could try uninstalling the DCM and then installing its previous version, 3.0.24.59748, to see if that makes any difference. At this point, anything is worth a try.
https://software.intel.com/en-us/articles/previous-intel-realsense-install https://software.intel.com/en-us/articles/previous-intel-realsense-install
返信
