Items with no label
3340 Discussions
SR300 usb-disconnects when camera turns active - unusable
MMark14
I have a SR300 camera and have major problem with is. When an application is activating the camera, the led gives one little blink and the camera disconnects itself. I hear the windows USB-disconnect sound which is followed by the USB connect sound.
Every application I try gives the same result.
This problem did occur the last week sometimes. With a couple of tries it did work, but now I never got it working anymore. I tried everything:
Install intel_rs_dcm_sr300_3.3.27.5718
install intel_rs_dcm_sr300_3.2.26.6137
intel_rs_sdk_offline_package_10.0.26.0396
I even completely re-installed my laptop because I thought it has something to do with a windows update.
Tried every usb3 port. Reinstalled everything a thousand times.
This Video demonstrates the problem :
What could this be ? Can anybody help out ? This is driving me nuts ...
Hardware: Razer Blade 2016 refresh
Windows: Windows 10 Pro
SKumb1
Hi Samir Dudani,
Could you please share hardware configuration of your PC.
Thanks!
ShyamQuadtech
SKumb1
Hi Jose,
As you suggested, we have tried with default power cable provided with camera, but problem not resolved.
Then we tried with below cable having extra usb 2.0 port along with 3.0 which provides 1mA extra power.
but camera still not working.
If any problem with my hardware configuration please guide me.
Waiting for your response.
Thanks & Regards,
ShyamQuadtech
Hey Shyam,
My system:
Good luck.
SHira1
Hi intel_corp
I have same problem.
I didn't resolve, this method (/message/440280# 440280 https://communities.intel.com/message/440280# 440280).
I upload sdk_info.exe's log.
Please let me know what I can do.
SHira1
Additional info.
"CameraExplorer", "Raw Stream", "Hands Viewer" are unavailable.
This code is available.
But, unavalable if it's enable Color Stream.
Is SR300 unavailable multi stream??
Hi OpenFields,
Thanks for your interest in the Intel Realsense Platform.
Could you try to uninstall the DCM and restart your computer? Then plug in the camera to a powered USB 3.0 port (look for the lightning symbol) and wait several minutes while monitoring Device Manager, until Windows Update starts and installs the drivers. If this doesn't work can you reinstall the chipset drivers (which should include USB drivers).
I will be waiting for your reply, have a nice day!
-Jose.
SHira1
Hi.
My problem has not been fixed.
[method 1] install DCM(intel_rs_dcm_sr300_3.3.27.5718) => "Camera Explorer" and Samples is failed.
[method 2] uninstall DCM and restart.
[method 3] wait several minutes and Windows Update. => "Camera Explorer" and Samples is failed.
* "failed" means : wake "Camera Explorer" or push Sample's"Start" then sounds driver off (as soon as sounds driver on).
Current type SR300 is unavailable.
But, old type SR300 is available in [method 1].
I'm worried initial failure.
But, both SR300 is available on another PC.
Surface Pro: Windows 10, core i7 gen4
Sony VAIO: Windows 10, core i7 gen4
I want to work current version on my desktop.
What should I do??
Hi OpenFields,
Could you provide me the system information of the PC where your SR300 works? In order to generate it, please press on your keyboard WinLogo + r, then enter msinfo32, then click on File >> Export. This process might take some minutes, once you have generated that file please send it to us in your next reply.
-Jose.
SHira1
Hi.
This is. OK??
Hi OpenFields,
I apologize, I didn't notice that you put two system information in your zip file. Looking at both computers they have the same hardware specs, I would recommend to try to update to the latest version of Windows. Let me know if this works.
-Jose.
ABand1
Hi There,
Until some weeks ago everything seemed to be fine with the powered USB hub. Unfortunately I'm experiencing the disconnection problem again. When I run the RawStreams.exe, sometimes the camera fails to start (especially when depth and color videos are streamed together). Moreover, the few times when camera works, it disconnects at the end, once I push the "Stop" button.
Let me know if you need other information
Best Regards
Hi band0,
I'm sorry to hear that the USB hub is no longer working for you. Did you already installed the latest version of Windows?
Please let me know in order to assist you, have a nice day!
-Jose.
Hi band0,
Were you able to fix your issue? Please let me know, in order to assist you.
-Jose.
ABand1
Hi Jose,
Thanks for you reply. I have the latest version of Windows. Now I'm trying to reinstall reinstall the chipset drivers (for the second time), to see if I can fix the problem.
However, does anybody know why the camera does not work without an external hub?
Best,
Hi band0,
Please let me know if reinstalling the chipsets fix your issue, I think that you might find useful this guide .
The reason that some users are in need of an external hub, is because their computer ports aren't given the necessary power to the camera, this is why we recommend to connect the camera to a power USB 3.0 (look for the lightning symbol).
-Jose P.
Hi band0,
Were you able to fix your issue? Please let me know in order to assist you.
Have a nice day!
-Jose P.
MPryo
I had the same issue as others posted here. I solved it with the following steps:
  1. Go into Device Manager
  2. Right click the Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft) (or similar for your device)
  3. Click Properties
  4. Click the Power Management tab
  5. Deselect Allow the computer to turn off this device to save power
Hi Xilnik,
Thanks for your interest in Intel Realsense Platform.
We appreciate the feedback you have provided! This will be helpful to other users having this issue.
Have a nice day!
-Jose P.
FLeac
It worked for me too! Thank you.
ABand1
Hi Jose,
The camera sometimes works and sometimes is not even detected (when connected to the hub). Actually, my hub is an external powered USB 3.0, but doesn't have the lighting symbol on the usb ports. Is this the problem? May I have requirements of power supply in order to buy an external hub that works?
Hi band0,
Have you tried to connect your camera to another computer with a power USB 3.0 port?
Also have you try these steps provided by Xilnik :
1) Go into Device Manager
2) Right click the Intel(R) USB 3.0 extensible Host Controller - 1.0 (Microsoft) (or similar to your device)
3) Click Properties
4) Click the Power Management tab
5) Deselect Allow the computer to turn off this device to save power
-Jose P.
