Items with no label
3340 Discussions
String test fail on running the Ipdt 64 on Pentium d procesdor
SBali4
Sir
I am facing the string test fail problem when I run Ipdt64 diabaligagnostic utility.kindly provide a solution for the same​. Thanks and regards sures
AlHill
The solution is to ignore the string test. Your processor is too old.
Doc
SBali4
Sir thanks for your reply, however I find it strange the ipdt 64​ utility would clear all other test in the list except string test. Kindly check and confirm what is missing inside the utility that it cannot detect the processor internals ? Do I need to update the processor microcode updation or firmware in order to detect the processor string kindly check and confirm. Thanks and regards Suresh bal
AlHill
You are running a 15 year old processor on a DEAD operating system.
There is no microcode or firmware update.
What you need to do is come out of the dark ages, and purchase a new system that is made in this decade, not two decades ago.
Doc
