Items with no label
3338 Discussions
The external Interface from the D435i, is it only USB C? If yes can we use a USB type C to Type A cable for interfacing to the processor? Any other interfacing that needs to be done for communication and configuration?
suni
MartyG
The RealSense 400 Series cameras use USB Type-C (full-size USB A to micro-size C). The full size USB A end plugs into the computing device or USB hub, and the micro-end plugs into the side of the camera. The cable, which is supplied with the camera, is all you need to start using the camera.
BTW, the RealSense forum has now moved to a new location, so you should post future questions there please in order to receive assistance from the RealSense support team. Thanks!
https://support.intelrealsense.com/hc/en-us/community/topics
