Items with no label
3341 Discussions
Whether the firmware upgrade will affect the internal and external parameters of the camera?
fwang22
I upgraded the camera firmware. Will this affect the internal and external parameters of the camera?
MartyG
I would expect the intrinsics and extrinsics of the camera to remain the same. These parameters are typically changed by deliberate use of calibration software, such as the SDK's 'Dynamic Calibrator'. It is possible to accidentally alter parameters by giving the camera a physical shock such as a hard knock or a drop on the ground, requiring a calibration to correct them. Firmware changes should not affect intrinsics and extrinsics though.
JesusG_Intel
As of June 10, 2019, Intel® RealSense™ product support has moved to https://support.intelrealsense.com. All new community posts must be submitted at https://support.intelrealsense.com. If you have existing threads on this Forum that were opened before June 10, 2019 and are not resolved, please re-post your question at https://support.intelrealsense.com. This Forum will continue to be searchable after the cutover.
You will still be able to create questions on this forum but those questions will not receive support from Intel. If you desire Intel support, please go to https://support.intelrealsense.com.
