Items with no label
3338 Discussions
d435 depth camera
EAlta
How can I get the depth (in meters for example) of each pixel of the depth image, given by the realsense d435 depth camera, obtained by the RealSense Viewer?
MartyG
The link below suggests that you could load your ply file into the MeshLab software (sometimes used to convert RealSense 2.0's ply pointclouds to solid-mesh 3D models) and convert it to a depth map with the 'depthmap' shader.
https://stackoverflow.com/questions/42754843/ply-polygonal-mesh-to-2d-depth-map python - .ply polygonal mesh to 2D depth map - Stack Overflow
EAlta
MartyG jb455
That could be an option, but I would like to try with the sdk's functions. I alrready have the intrinsic values but I dont really understand what does the ""https://github.com/IntelRealSense/librealsense/blob/5e73f7bb906a3cbec8ae43e888f182cc56c18692/include/librealsense2/rsutil.h%23L15 rs2_project_point_to_pixel(...)" function return. In the documentation, is said tha it converts a 3d point into a 2d image, but is it a depth image? and Do I have to introduce every point (x,y,z) independently?
MartyG
JB will be better able to offer advice on this question, as RealSense stream programming is not one of my specialist areas, unfortunately. Good luck!
jb455
Valued Contributor II
That function projects a single 3D (xyz) point to a (uv) pixel in the depth image. The `point` parameter you pass will be an empty point object which is filled in by the function.
You'd probably want to start with a float array the size of `depth.width*depth.height` initialised with zeroes, then loop through your point cloud (xyz), apply the function on each point and then fill in the `(u + v*depth.width)`th element of your float array with the z value of the point. Then when you're finished the array will be filled in with all the depth values, and any zeroes that are left will represent points that had no depth data. You can then process that however you want. If you want an image you'll probably need to use OpenCV or something to visualise the depth data.
EAlta
Thank you jb455
Im going to apply the algorithm you propose.
What are the "u" and "v" values that returns the projection function?
I applied sdk´s function "rs.rs2_project_point_to_pixel()" with the following inputs:
- Depth intrinsic values: width: 424, height: 240, ppx: 214.063, ppy: 120.214, fx: 213.177, fy: 213.177, model: Brown Conrady, coeffs: [0, 0, 0, 0, 0]
- point to convert (from pointcloud): [-0.968, -0.582, 1.03]
The output from function is: [13.718368530273438, -0.24103546142578125]
jb455
`u` and `v` are the `x` and `y` coordinates in the depth image, which are `point[0]` and `point[1]` (the output values). You'll probably need to round the values and cast as `int` so you can get/set items in the array.
